NZXT H440 White
Go to solution Solved by TonyTheNain,
19 minutes ago, liamdoyle27 said:
Snip
18 minutes ago, Aytex said:
snip
Thank you! I'll buy better ones
Yes it does, but apparently not very good quality. Could install your own in place of the original ones??
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
https://linustechtips.com/topic/801101-nzxt-h440-white/#findComment-10074803
