Hi
I have been looking into doing something like Linus did with 2 gamers 1 CPU but just needed some questions answered.
I have a 256gb ssd and a 1tb hard drive and am thinking if getting 2 cheap 500gb hdd for the vm's so if I wanted to could I put the 2 500gb hdd in my case unplugged for when I am not using my PC as a vm and then plug them in and boot off a USB with unraid when I do. Is it possible?
Here are my specs if you want to know:
3960X @ 4.3 ghz
32 gb of ram
Gtx 980 sli
https://linustechtips.com/topic/801002-virtualization-help/
6 minutes ago, TDCDigital said:
Hi
3960X @ 4.3 ghz
32 gb of ram
Gtx 980 sli
or leave them connected and just f12 or boot menu when restarting to choose unraid?
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/801002-virtualization-help/#findComment-10073596
8 minutes ago, TDCDigital said:
Hi
3960X @ 4.3 ghz
32 gb of ram
Gtx 980 sli
Id just use fedora instead of unraid, its free and easier to use.
You can use one hdd.
Normally the vm for 2 games isn't suggest and is buggy and a pain to use at times, Id really suggest just getting a cheap 150 dollar old dell optiplex and put the second 980 in there.
https://linustechtips.com/topic/801002-virtualization-help/#findComment-10073611
I want the sli configuration for driving high setting 4K gaming and the vm for when my friend comes over and I don't want to have to open a PC and switch gpu every time he comes over so thats not really an option
https://linustechtips.com/topic/801002-virtualization-help/#findComment-10073637
