I need help! Dust buildup is insane!!!
Solved by Andrewf,
16 minutes ago, Pachuca said:
Not to mention that solving airflow is case by case per case. "Cold air in how air out" doesn't answer any of my questions.
Also with different types of fans, neutral air pressure isn't the "easiest".
For someone who actually takes time to help me rather than just posting a video, do you recommend I just do some math with the airflow and cfm of each fan and get as close to neutral as possible?
