I have a ssd and a hard drive and the hard drive is not shown in windows but in bios it is, i've tried to reinstall the windows and I can't format it, disk managment doesn't show it.
Sorry for my bad english, thank you in advance!
Edited by Ducu278
forgot something
https://linustechtips.com/topic/800296-hard-drive-issue/
are you able to try it externally with a usb adapter like this
https://www.startech.com/HDD/Adapters/USB-3-to-SATA-or-IDE-Hard-Drive-Adapter-Converter~USB3SSATAIDE
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
https://linustechtips.com/topic/800296-hard-drive-issue/#findComment-10066444
So the SSD shows up but not the hard disk right? Try touch its surface when you turn the PC on. Do you feel vibrations? If you don't then the disk isn't spinning at all. That can be a loose SATA power cable, or broken HDD. If it does spin, then probably the SATA data cable got loose/damaged.
Desktop benching:
https://linustechtips.com/topic/800296-hard-drive-issue/#findComment-10066478
