Mining with a 960M?
Solved by BuckGup,
1 hour ago, Matt1656 said:
It's the issue that in a normal PC the GPU and CPU can be 65C all day long as they have their own coolers and are spread apart. Since a laptop is condensed 65C is spilling over onto the motherboard next door and the battery. Usually by doing something like this you will degrade battery life rapidly. A 960M would literally get you pennies a day and cost dollars to run. Not worth it. Just go to bitcoin faucets for that kind of money
