Not that I need to, but I was thinking about putting 120mm AiOs on my 1050ti and 950 FTW. I don't know if they'd even fit under the shrouds, or if I'd have to make my own, but I could probably manage.
My real question is if they'd even fit, and if they'd be effective at all since there's no xPU core lid.
Has anyone tried this?
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/
I've seen people put cpu air coolers on gpus so I imagine it may be possible but your experience may vary. Would you do this in your current rig? It looks kinda full, where would you put the rad?
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062522
I assume you say my Imgur album.
I can put them up front where the two LED fans are now. I'd probably have to mod the case, but I don't plan on resale anyway.
The other I can put in the rear.
What about stacking the radiators in push-push-pull or push-pull-pull? Does that work? Like fan-rad-fan-rad-fan?
2 minutes ago, The Benjamins said:
GamerNexus made hybrid cards with AIO's before. depending on pump size they can fit under the shroud.
Hmmmmmmmmmmmmm
The pump on my current CPU is quite small, a lot smaller than I initially thought it would be. I would get two 120mm of my current model and use those.
Could I also link the pumps onto a single 240mm? Like mod the coolers? I know that fiddlign with AiOs isn't cost effective but I've not really done water cooling before and kits are expensive. I'll have about $400 at my disposal tomorrow, if a client doesn't cancel.
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062570
sounds like a g12  would be good for you
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062580
But it ugly and doesn't fit my case A E S T H E T I C very well. Everything has a sort of angular fit to it. The case, the GPU shrouds, the AiO pump (one of the reasons why I chose this one instead of a round shaped pump)...
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062596
Hmmmmmmmmmmmmm
most AIO's do not make it easy to refill or disassemble, EK had a great AIO but V1 is discontinued and V2 was going to be out but got delayed to Q4. they used all custom loop parts so it was easy to upgrade them.
why not just get a 240mm AIO?
EK has kits that would work for under $400. the new Gaming fluid ones are $250 for a CPU/GPU loop on a 240mm rad IF it is a 10xx founder card. and you can get a standard kit for $300 ish and buy a GPU block and 2 fittings for $100
if you give me a parts list I can see if I can wipe something up under $400.
if you want to annoy me, then join my teamspeak server ts.benja.cc
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062607
Because I want to cool two GPUs, not just one.
GPU1: GTX 1050 Ti FTW (single 6-pin)
GPU2: GTX 950 FTW (single 8-pin)
Case: Thermaltake Versa N25 "DragonScale"
Current CPU AiO: upHere 240mm AiO
I could do it with three 120mm AiOs - two up top and one in back, but that seems silly and there'd be a lot of tubing.
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062631
I would maybe put the rad up front like you were saying above the hard drives. That is the only place I can see it fitting very well. You could mount it to the case there and have a fan pulling the air through
I wouldn't, that sounds really uncomfortable
The Impossibox
WhisperingKnickers
x58 Fan Page
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062635
One of them, yes, will definitely fo in the front of the case.
Ahahahahahaha
Yeah, the tubing from my CPU 240 would get in the way
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062647
What if you moved the rad for your CPU to the other top spot, to move it away from the back of the case, that would move the tubes and you could get a rad in the spot of that back fan
The Impossibox
WhisperingKnickers
x58 Fan Page
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062659
Because it's 240mm and takes up the whole top. The top of mu case supports 240mm only.
If I got 3 120MM coolers, I could have both GPU brads up top, and the CPU block blowing out the back. I don't know what I'd do with the 240mm, then.
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062673
Do you use your disk drive? If not then you could take it out and the tubes for the 240 might be long enough to spin the rad around and have the tubes near the front of the case
The Impossibox
WhisperingKnickers
x58 Fan Page
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062687
Yes, I use all five of them (those are hard drives, not CD drives). There are three HDDs un the bottom, and there are two HDDs up in the 5" bay, I'm using a bracket to mount one of the two drives up there. The other is in the 3.5" diskette/accessory slot.
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062698
You could try this.
https://www.ekwb.com/shop/ek-kit-l240-1
2x https://www.ekwb.com/shop/ek-vga-supremacy-nickel
4x https://www.ekwb.com/shop/ek-acf-rotary-fitting-10-16mm-nickel
That would get you right at $400. You need to double check that the 1050ti GPU mounting holes is 53x53mm - 58x58mm.
May want to get some cheap copper heatsinks for the VRAM and VRM.
https://linustechtips.com/topic/799948-use-cpu-blocks-on-gpus/#findComment-10062766
