M.2 sata is an space saving option over an two and half inch ssd
PCIE ssd are connected directly to the cpu and doesn't have 600 MB/s bottleneck,thus providing faster overall perfomance over an sata ssd which has has a bottleneck
You might know that m.2 also capable of pcie  ssd's speed
29 minutes ago, JackDoyne said:
What is the difference between a PCIE SSD and m.2 SATA SSD?
By PCIe I assume you mean something like the Intel SSD 750 that literally plugs into a PCIe slot like a graphics card or sound card would. M.2 is just a form factor and a slot. Some M.2 SSDs are still SATA and perform no differently from ordinary 2.5" SATA SSDs, and some are M.2 NVMe which communicate over PCIe.
I assume there's not much performance difference between NVMe SSDs that plug into M.2 versus those that plug into PCIe directly. Both are supposed to get 4 PCIe 3.0 lanes, so they should have the same bandwidth available. Any performance differences would likely come from the drives themselves.
PCIe SSDs look like Graphics Card.
while m.2 has it own slot
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
^That is M.2 drive in PCIe to M.2 adapter.
(M.2 uses PCIe to communicate, ie. it "talks" to pcie controller directly)
Adapter speed is limited by PCIe version MB/CPU supports, and what drive itself uses (gen 2.0/3.0 and x2/x4 link).
Ps. There are AHCI M.2 drives that utilise PCI-e (or M-Key), as well.
Example SM951 AHCI : LINK.
CPU : Core i7 6950X @ 4.26 GHz + Hydronaut + TRVX + 2x Delta 38mm PWM
MB : Gigabyte X99 SOC (BIOS F23c)
RAM : 4x Patriot Viper Steel 4000MHz CL16 @ 3042MHz CL12.12.12.24 CR2T @1.48V.
GPU : Titan Xp Collector's Edition (Empire)
M.2/HDD : Samsung SM961 256GB (NVMe/OS) + + 3x HGST Ultrastar 7K6000 6TB
DAC : Motu M4 + Audio Technica ATH-A900Z
PSU: Seasonic X-760 || CASE : Fractal Meshify 2 XL || OS : Win 10 Pro x64
NVMHCI is the logical device interface for non volatile storage over the PCIe bus.
2.5-inch form-factor NVM devices that provide a four-lane PCI Express interface through the U.2 connector, or using the M.2 interface for internally mounted computer expansion cards on the board through a PCIe max 4x interface.
