Hey! Im new to the forums, so forgive me if im being a noob.
im upgrading my PC this christmas, and im on a budget. Im looking to upgrade the processor, graphics card, and power supply. (maybe not all at once)
i currently have a 650 ti, and an i3-3220, and its not enough for my needs.
I was wondering if an R9 280x and an FX-8350 would be enough to run the newest games on ultra settings at 1080p 60fps, and if so what wattage power supply will i need?
And is this overkill? could i save some money? Your advice is appreciated, and i would like to know what you guys would reccomend.
thanks, Jamie.
i5 3570K  4.5 GHz   Hyper 212 EVO | EVGA GTX 770  |  MSI B75MA  Thermaltake Commander  |  8GB Kingston HyperX  |  WD caviar Blue 500GB 24" LG Flatron 1080p  Coller Master i700w
https://linustechtips.com/topic/79982-need-advice-for-an-upgrade/
The 280x will be fine for what you want to do for now... but as games get more advanced the card wont do as well. If you look at Slicks Assassins Creed testing an overclocked 280x can only do 32fps@ultra so eventually the card wont do as well. You could go down to 8320 or fx-6300 for a cpu you wont see a huge difference. A 600w psu is what I would recommend, maybe a 550w if you had a different cpu.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
32 fps? man thats brutal. I heard AC4 is really unoptimized, is that the case here or is the card really that limited?
I don't think drivers have been updated to help and its poorly optimized. The card is just rebranded 7970 so I believe its just the game and not so much the card as it the 280x can do about 57fps in bf4. If you wanted to be over the 60fps mark and stay above it a 290 maybe the card to get. But for now a 280x will be fine for around 60fps gaming.
It's probably a bit overkill for an upgrade.
What kind of games are you planning to play? Budget? What are you current specs?
