HDD Clicking Sound
Go to solution Solved by ARikozuM,
3 minutes ago, DerpedUpCow said:
Toshiba DT01ACA200
Don't know about that one, but you don't have to sweat bullets over this. It's likely fine.
Today I booted my PC. As it was loading the bios the HDD started to make a loud rapid clicking sound. After about a minute the clicking sound starts to fade away, within 5 seconds it stops completely. My HDD is now dead silent. This has happened a couple of times in the past, but rarely occurs back to back. Should I be concerned?
https://linustechtips.com/topic/799432-hdd-clicking-sound/
Are you booting from the HDD? It could likely be the actuator adjusting itself.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/799432-hdd-clicking-sound/#findComment-10056891
Its either you will need a NEW ONE or you should DEFRAG. Here's an article about defragging. I do it every 2 months. If that doesn't fix it, let us know! :D
Intel i7-7700K 4.52GHz || ASUS RoG Maximus IX Hero || 2x G.SKILL TridentZ RGB 8GB || Samsung 960 EVO 250GB || Nvidia GTX 1080 Founders Edition || Thermaltake Toughpower DPS G RGB 850W || Corsair H100i V2 || Thermaltake Core X71 Tempered Glass Edition || WD Blue 1TB || Razer Kraken 7.1 Classic || Razer DeathAdder Classic || Razer BlackWidow Ultimate Classic
https://linustechtips.com/topic/799432-hdd-clicking-sound/#findComment-10056897
Just now, DerpedUpCow said:
Yes, I am booting from the HDD.
Then it's just the actuator moving across the disk. You may not have noticed until now.
I would search for a new HDD, if you can, for possible compliment to the existing drive.
https://linustechtips.com/topic/799432-hdd-clicking-sound/#findComment-10056905
Is this common/completely normal then?
https://linustechtips.com/topic/799432-hdd-clicking-sound/#findComment-10056922
Normal. How old is the drive?
https://linustechtips.com/topic/799432-hdd-clicking-sound/#findComment-10056941
I got it about 2 years ago.
Do you know what model it is? Some of the older drives don't have a piezoelectric motor for finer, quieter movement so the mechanical actuator has to move far away before moving closer.
https://linustechtips.com/topic/799432-hdd-clicking-sound/#findComment-10056962
Toshiba DT01ACA200
https://linustechtips.com/topic/799432-hdd-clicking-sound/#findComment-10056986
