So I have a corsair spec 1 case (which comes with a 120mm corsair fan.) I would like to put 4 more fans into the case, 2 140mm intake, 2 120mm exhaust, but my motherboard only has 2 fan connectors. I have selected two fan adapters that would allow me to use all of my fans. I was wondering if my specific motherboard (ASRock AB350m Pro4) can support that power draw from one port. I can't find the max power from one fan connector in the manual, so I need some help to figure this out.  Thanks!
TL;DR: I don't want my mobo to explode from excessive power draw.
Here is a list of my case, the fans, and adapters.
PCPartPicker part list: https://pcpartpicker.com/list/NDBGFd
Price breakdown by merchant: https://pcpartpicker.com/list/NDBGFd/by_merchant/
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($77.98 @ Newegg)
Case: Corsair - SPEC-01 RED ATX Mid Tower Case  ($39.99 @ Newegg)
Case Fan: Cooler Master - SickleFlow (Red) 69.7 CFM  120mm Fan  ($6.28 @ OutletPC)
Case Fan: Corsair - SP140 49.5 CFM  140mm Fans  ($28.99 @ Amazon)
Other: Silverstone CPF02 11.81" 300mm (100mm/100mm/100mm) Black Sleeved  ($6.98 @ Newegg)
Other: Silverstone CPF01 3.94" PWM Fan Splitter Cable  ($3.99 @ NCIX US)
Total: $170.49
Generated by PCPartPicker 2017-06-27 02:11 EDT-0400
https://linustechtips.com/topic/799227-need-help-with-fan-adapters/
Depends on what you are looking for. If you are fine all case fans running at same speed, you should get powered PWM splitter/hub and connect all to PWM chassis fan header. Or use 3-way for CPU header and 2-way for chassis header. Seems like mobo has limited support for controlling 2nd chassis header.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
