On 6/24/2017 at 8:34 AM, brendon1996 said:
 Manli GeForce GTX 1060 BlowerFan 6GB DDR5 192-bit would this card be good for mining ? Cost: 350 USD
 I would buy 3 of them .
Would be alright. 1060 6gb cards mine Ethereum and Zcash pretty close to the same profit per day, but dual mining Ethereum and Sia coin will yield the most. Also 350 is pretty high, you'd get a faster ROI buying like 6 1050 ti's at 140 each off new egg instead. Lower hashrates but being that 2 of those are 280 and the hashrate would be higher than a single 1060 it would be worth it even with the additional riser cost. Also 1050 ti's make more mining ETH + Sia than Zcash by a long way.
