If this cougar case comes in white its perfect for  you
Also,  thermaltake has a rgb CPU block
http://www.thermaltake.com/products-model.aspx?id=C_00003010
Want to custom loop?  Ask me more if you are curious
thanks
that water block is great but I don't quite like the case. i saw it earlier when j2c posted it and the from is a little ugly to me.
But did I mention that is one of the coolest waterblocks i have ever seen.
2 minutes ago, Captain Ninja Kid said:
thanks
It uses the same RGB system as the thermaltake rgb fans as well
