i7 6700 Randomly Started Overheating
Go to solution Solved by knightslugger,
5 minutes ago, pete6274 said:
How would I remove an air pocket?
tipping the rad/hoses/coldplate to get the air to move through the area. sometimes a tap tap tappy tap on the components will get it to move (stiction).
Hi all, I'm afraid I'm in need of some help. I have just recently built my first PC and it has been working perfectly for the past few months. However I have just noticed the fans spinning much faster than usual. When I noticed this I installed NZXT's Cam software and found my CPU (Intel Core i7 6700) to be running at over 90C while only under 40% load! I can't seem to find the problem. My cooler is a Cooler Master Nepton 120XL and my mother board is an ASUS Maximus VIII Hero. Any ideas as to what could cause my CPU to all of a sudden start running so hot?
https://linustechtips.com/topic/797248-i7-6700-randomly-started-overheating/
I think the first step here would be to look at your cooler and reapply thermal paste.
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
I second this.
Also listen to the pump. if it sounds quiet or isn't making noise it might have died (doubt it though)
Have you changed any other hardware since this temp jump?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
I was worried I might hear that... thanks for the advice... unfortunately my current work situation is going make reapplying thermal paste a bit of a challenge... I haven't changed any hardware since building the PC. As for the pump, this is probably a nood mistake but I have no idea what it should sound like under normal operation. It does seem to be running though.
Not related to the issue, but you could overclock that 6700 if you don't mind flashing a custom BIOS
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
10 minutes ago, pete6274 said:
Is there by any chance a way I can check the pump is functioning other than listening to it?
just touch the cold plate. you should feel a slight vibration.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
I'm afraid I don't quite have the know how for that just yet... but that is something I'm keen to look into if I can just get the thing to cool properly.
It's possible that there is an airpocket trapped in the impeller causing a hydrolock type of situation... or the impeller broke. otherwise for sure check into getting the TIM replaced and the coldplate remounted.
System specs:
You can try touching both hoses and the radiator (if you have push-pull, check the air exhaust with your hand), and see how they feel to the touch. If I'm not mistaken, a large temperature difference between the hoses could mean a dead pump.
30 minutes ago, knightslugger said:
It's possible that there is an airpocket trapped in the impeller causing a hydrolock type of situation... otherwise for sure check into getting the TIM replaced and the coldplate remounted.
There was that temperature difference in the pipes yesterday but I'm not having the same issue now... could the temperature difference also be related to an air pocket?
The air coming out the radiator is cool.
System specs:
