3 minutes ago, Age of 9394 said:
After watching this video https://www.youtube.com/watch?v=yZJciVoBaRg&t=371s,
I want to know it is possible side panel cases fan use magnetic to power?
Alienware already has it in their desktops.
11 minutes ago, Age of 9394 said:
Only Alienware had wireless cases fan design ?
So far it's the only one I know of, and they had it for at least 8 years or so, since socket 775 or probably earlier. Some never knew about it cause Alienware, ewwww, not going to touch that with a 10 foot pole.
It's not really "wireless"
It's just a side panel that has electrical contacts to the case for powering the fan.  If magnets are involved, all the magnets do is hold the contacts together well enough for an electrical connection.  Those contacts are functionally no different than wires or any other electrical connector.
SFF-ish:  Ryzen 5 1600X, Asrock AB350M Pro4, 16GB Corsair LPX 3200, Sapphire R9 Fury Nitro -75mV, 512gb Plextor Nvme m.2, 512gb Sandisk SATA m.2, Cryorig H7, stuffed into an Inwin 301 with rgb front panel mod.  LG27UD58.
Aging Workhorse:  Phenom II X6 1090T Black (4GHz #Yolo), 16GB Corsair XMS 1333, RX 470 Red Devil 4gb (Sold for $330 to Cryptominers), HD6850 1gb, Hilariously overkill Asus Crosshair V, 240gb Sandisk SSD Plus, 4TB's worth of mechanical drives, and a bunch of water/glycol.  Coming soon:  Bykski CPU block, whatever cheap Polaris 10 GPU I can get once miners start unloading them.
MintyFreshMedia:  Thinkserver TS130 with i3-3220, 4gb ecc ram, 120GB Toshiba/OCZ SSD booting Linux Mint XFCE, 2TB Hitachi Ultrastar.  In Progress:  3D printed drive mounts, 4 2TB ultrastars in RAID 5.
