BeQuiet Silent Wings 3 or Corsair ML 120mm Fans?
AdamRedfern
Which one should I get for case fans for my Silverstone Raven RVZ01 - http://amzn.to/2sTdaWA
Silent Wings 3 - http://amzn.to/2rUCWod
Corsair ML 120mm - http://amzn.to/2tsvC5l
Edit - For Case Fans
Thanks!
CPU: Intel i7-4790k | Cooler: Corsair H110i GT | Motherboard: MSI Z97I AC  | Graphics Card: SAPPHIRE R9 280  | http://uk.pcpartpicker.com/p/pszsdC
Links to My Site's!
http://adamredfern.co.uk
http://rewinded.co.uk/
http://yewtreeservices.co.uk/
http://ssstelecom.co.uk/
http://boatv.co.uk/
Pretty sure the difference will be quite negligible (in the margin of error maybe) in terms of temperatures. Just choose depending on the noise, price and visual side (if that matters). I don't think you can go wrong with either one.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
be quiet silent wings all day over corsair
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
They're not in the same category. SW3's are very quiet fans that perform alright and ML120's are high performance fans that are relatively quiet.
It's a decision between whether you care about acoustics or not at all.
Thanks!
just bought a set of ml120mm corsairs, will let you know how they are and can send you some pictures when/before installation
Be Vigilant or Jump Off
I have 3 silent wings 3 that came with my dark base 900 pro (pro 900? pro base 900?)  They move okay amounts of air but they definitely live up to the company name. be quiet. they're quiet, have a nice long pwm cable and they look okay,  not bad but not overstated, they're just there, which is fine, they aren't in a noticeable location anyway.
I also have the ml 140 pro and a couple ml 120 pros. They move tons of air and have great static pressure but they get loud for it (of course). Fortunately they are also pwm so you can control them but they are definitely not as friendly to the ear as the silent wings.
really two different animals.
One's a silent semi decent mover.
The others a turbo high pressure and noisy beast really best for radiators i'd imagine.
Thanks!
try out Thermal Bench testing to actually see the statistics for both of the fans before you buy them
  • 3 weeks later...
Thanks, that would be great! :D
Links to My Site's!
http://boatv.co.uk/
