I just finished ordering the last of my parts and am now pretty nervous as the time to actually build the pc rather than plan it out and save money, has finally come. Any tips you experienced pc builders would like to share with me? What thing should i make sure i do and dont. Anything would help. Also can anyone explain or link a video to how to connect to front panel connectors as i am still a bit confused on that. Any help would be greatly appreciated!
My build:
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  ($327.89 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.99 @ Amazon)
Thermal Compound: ARCTIC - MX4 4g Thermal Paste  ($5.79 @ OutletPC)
Motherboard: Asus - STRIX Z270-E GAMING ATX LGA1151 Motherboard  ($189.49 @ SuperBiiz)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($126.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Asus - GeForce GTX 1080 8GB ROG STRIX Video Card  ($564.98 @ Newegg)
Case: Phanteks - Enthoo Pro M Tempered Glass ATX Mid Tower Case  ($107.98 @ Newegg)
Power Supply: EVGA - SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.88 @ OutletPC)
Operating System: Microsoft - Windows 10 Home Full - USB 32/64-bit  ($104.99 @ SuperBiiz)
Case Fan: Corsair - Air Series SP120 High Performance Edition 62.7 CFM  120mm Fan  ($15.39 @ Amazon)
Monitor: Dell - U2515H 25.0" 2560x1440 60Hz Monitor  ($279.99 @ Best Buy)
Keyboard: Corsair - K70 LUX RGB Wired Gaming Keyboard  ($159.99 @ Corsair)
Mouse: Logitech - G502 Wired Optical Mouse  ($59.00 @ Amazon)
Total: $2116.18
Generated by PCPartPicker 2017-06-20 17:28 EDT-0400
https://linustechtips.com/topic/796199-finale-tips-for-first-time-builder/
Haven't built it yet but:
1. Watch a bunch of build videos. They help a lot for me.
2. Make sure you touch the case/PSU often to avoid static charge and breaking your components.
3. If you have a friend that is also interested in PC building, bring him/her along. It's always better to have two hands.
Best of luck!
EDIT: Here's a great video: https://www.youtube.com/watch?v=IhX0fOUYd8Q
My build:
Total: $2116.18
With that build, you should definitely get a SSD. Also, you can probably tone down the motherboard or keyboard in order to get a 144hz monitor, which will feel way nicer than the 60hz
On your mobo and in its manual there's a part that tells you which pins connect to which parts of the front panel.
Your case has the connectors.
Look at the connectors and match up the connectors to the headers on the mobo.
Also, did you order everything already? Because psu is quite meh for the price and no ssd in a build this expensive is kinda eh....
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
My build:
Total: $2116.18
Also, sorry for double post, but you can buy windows 10 from kinguin for around $20-30
Don't forget to plug in the CPU power.
Plug the RAM in to the correct slots.  When you only have half the slots occupied you want to put it in the ones typically labelled A1 and A2.
If it doesn't turn on, make sure you flipped the PSU on.  And you may have just not wired the power button correctly.  Only LEDs have + and - on their connections.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
Already bought the parts man i had a really hard time deciding if i should go for an ssd but in the end decided to put the money in a nice motherboard and keyboard and wait a little longer for things to load. In my opinion 2 minutes for windows loading is not the end of the world as for the 144hz im not very competitive in games and would much rather have the higher resolution.
Best of luck!
lol ive watched that video like 6 times now it was really helpful ima watch it again.
Since the fans are 3 pin can i connect them to the 4 pin fan header on the motherboard? If i can does it matter how i plug them in?
Yes you can connect 3 pin to a 4 pin header. They should only plug in one way. Depending on the board they might run at 100% so you might need to adjust the speed with fan software or in the bios etc.
Yup you can, just make sure to connect them to the case fan headers not the CPU fan headers so that you can control them.
EDIT: And make sure that the little notches line up.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
