What would be a cost effective way to upgrade my main computer to run modern games on ultra? I'm honestly struggling to figure this one out on what parts to save for etc etc.
Current build v
cpu: AMD - FX-6300 3.5GHz 6-Core Processor
cpu cooler: Cooler Master - Hyper 212 EVO
gpu: EVGA - GeForce GTX 750 2GB Superclocked
mobo: MSI - 970A-G43 ATX AM3+ Motherboard
ram: Corsair - Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
psu: Thermaltake - TR2 600W ATX Power Supply
Possible full system upgrade, https://pcpartpicker.com/list/bFkNwV
*EDIT*
New system upgrade, https://pcpartpicker.com/list/d23wf8
Edited by NoCster
https://linustechtips.com/topic/795877-need-help-on-upgrading-my-current-build/
That's not an upgrade, that's a whole new system lol
I'd recommend Ryzen, specifically the R5 1600. better than the 7600K in everything.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Also, can you mark the parts you're carrying over from your old build as purchased in PCPP. makes it easy to see what to change and not to change when making a new parts list.
Laptop:
I would recommend Ryzen 1600 or 1600X instead of the i5-7600k. It will have similar performance in games, and because the 7600k doesn't have hyper-threading and has fewer cores, the Ryzen CPUs will be more effective in non-gaming applications. The GTX 1060 6GB should be good for modern titles if you are running at 1080p 60Hz.
His system has an identity and if it wishes for a ... would it be a sex change? ... new body, it isn't your business!
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
and they perform identically in today's games
plus, Ryzen will take a lead in the games of tomorrow, with proper DX12 and Vulkan.
Laptop:
Would I be able to keep a stable fps for a 75hz monitor?
Depends on the program, but you shouldn't have any issues since you can lower settings that aren't needed like AA.
I think yes but for more performance go for GTX 1070, and check my recommended monitor Here
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
5 minutes ago, NoCster said:
Does FreeSnyc only work with AMD cards? Sorry kinda new to this.
Yes, but linus has an explanation for G sync and freesync. and sorry for recommending nvidia with free sync monitor?
My head on 2019 :
ill look into a G-Sync monitor, very skeptical about AMD cards.
Ok, but remember you have to do something with V Sync while turning on G Sync
My head on 2019 :
