Hi guys,
Since yesterday my new build is live. It's a PC desk.
Everything works fine, but when I try to play a youtube video, the video starts to tear etc which makes it impossible for me to watch video's.
Sometimes it just dissapears, but most of the time it keeps happening throughout the video.
Pic at the end of the post.
Any solutions?
In the beginning I've had some problems with the sound aswell.
When I play music through the monitor or plug in my headset into the monitor and I put some load on the gpu (even video's, but mostly gaming) the sound starts to deform like crazy.
After browsing through the internet I used a usb for my mic, which solved the problem.
Any ideas on how to fix this problem? Maybe these problems have the same cause?
Did you install your drivers?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Just now, Maarten/Pine said:
Yes sir I did.
ok try plugging
plugging? in plugging in and out the dp cable?
That doesn't make sense, as the screen works fine.
Try reseating the cable and plugging in everything and did you install the right drivers and maybe try older drivers if it doesnt work
Can't install older drivers as I just got the system.
You can download the old drivers from the website from the board maker
I just installed a later BIOS version, all the other drivers are up to date. Can't download older gpu drivers afaik from nvidia.
