hi guy.  I want to build PC PC with i7 7700K.
Question 1 :
can I use this heatsink CPU I'm on a budget.  Cooler Master Hyper 212 EVO Universal CPU Cooler : http://www.microcenter.com/product/373900/Hyper_212_EVO_Universal_CPU_Cooler
Cooler Master HYPER T4 CPU COOLER : http://www.microcenter.com/product/411580/HYPER_T4_CPU_COOLER
Cooler Master Hyper 212X CPU Cooler with dual 120mm PWM Fans : http://www.microcenter.com/product/467072/Hyper_212X_CPU_Cooler_with_dual_120mm_PWM_Fans
Cooler Master HYPER D92 CPU COOLER : http://www.microcenter.com/product/435417/HYPER_D92_CPU_COOLER
which's one right here is  best ?
is it okay I can use this heatsink for CPU i7 7700K.
Question 2:
 Do you guy think one this motherboard  is good for i7 7700K.
http://www.microcenter.com/product/474112/GA-Z270-HD3_LGA_1151_ATX_Intel_Motherboard
http://www.microcenter.com/product/473034/TUF_Z270_MARK_2_LGA_1151_ATX_Intel_Motherboard
http://www.microcenter.com/product/475280/Z270_SLI_LGA_1151_ATX_Intel_Motherboard
http://www.microcenter.com/product/475276/Z270_TOMAHAWK_LGA_1151_ATX_Intel_Motherboard
Thanks for your help.
https://linustechtips.com/topic/794870-question-build-i7-7700k/
get a more basic less expensive z270 board and put more into the cooling
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/794870-question-build-i7-7700k/#findComment-10007278
Question 1 :
Question 2:
what he said, but don't go too far down the line. Yeah an Evo 212 will work, although the I7 7700K seems to be a hot chip no matter what you do, so depending on your silicon you might be ok, might not be
Yours faithfully
https://linustechtips.com/topic/794870-question-build-i7-7700k/#findComment-10007289
those coolers do work, all those mobo work yes, just remember the 7700k is notorious now for being very hot, i would get a better cooler unless you dont plan on overclocking very much maybe an h60 or something do you have a pcpp list? and what is your budget, do you have any parts already that youre going to be using?
https://linustechtips.com/topic/794870-question-build-i7-7700k/#findComment-10007291
Use PCPartPicker.
120mm coolers are often worse than similarly priced air coolers.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/794870-question-build-i7-7700k/#findComment-10007334
