im organizing a csgo competition for my school's charity event and have 11 pcs with 11 copies of csgo(one for spectating and admin). I want to know how to set up a custom competitive match and what kind of match i should use to have a match be a max of 30mins(only 8 hours in total for the whole competition). Also , there will be sixteen teams and the competition will be single elimination style. Also a lot of people are recommending best of 30/15 but i have no idea what that means. Pls help guys. It's in a few weeks.
Also, where we're holding it has no internet connection so we can only play on lan. im so screwed if i dont get this done so i'd really appreciate any and all help
https://linustechtips.com/topic/793130-help-organizing-csgo-competition/
Remove the formatting please can't read
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Here:
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Given your limited time span (30 mins per game) a better game could of been something like Overwatch as normal competitive csgo matches are a best of 30 rounds format therefore are likely to go on for longer than 30 mins. So that means first to 16 rounds wins or draw at 15 rounds all. You could half the required rounds needed to try and make sure the games fall inside of 30 mins.
This steam post might help you out with the actual logistics of it but its worth you putting in some more research http://steamcommunity.com/sharedfiles/filedetails/?id=452154031
Edit: Alternatively if you know the computers will have internet access you can just create a lobby and invite everyone set the mode to Competitive, when people enter the game make sure they choose the correct team and the 11th PC selects 'Spectator'. Of course you won't have the almost perfect latency of LAN but you might not care
Processor: Ryzen 5950x GPU: RTX 3080  Mobo: X570 Aorus Pro RAM: 32GB DDR4 3200Mhz CPU Cooler: Noctua NH-D15
First one of your computer need to run the server as detailed below :
https://steamcommunity.com/sharedfiles/filedetails/?id=230908126
Then you need to configure that server with your own mod, but 30mn per match is very hard to achieve ... Unless you do 15-20 round max. You can use that kind of mod : https://forums.alliedmods.net/showthread.php?t=225474
Or more easily : http://steamcommunity.com/sharedfiles/filedetails/?l=french&id=477696626
Just now, joshua_lotion said:
sorry im desperate and no one seems to use that thread
Just give them a few minutes. Problem is the mods will lock your thread if you double post. I quoted the other guy and pasted your post without formatting. If it's formatted, sometimes people with the dark theme can't read it.
Mouse: EVGA X17
but doesn't that require an internet connection to do?
Just now, PatrickK said:
doing 15-20 rounds would be to solution here indeed, but seems kinda odd and stupid if you ask me. Especially for CS:GO
I don't agree the OP idea, just giving "solution"... Maybe he can make short match in "overtime" like for calification and then full match for semi and final ?
ya prob but your solution to make a server requires an internet connection right?
For the first time configuration you need indeed a network connection, to setup the server, download the require files, and setup csgo on every computer. But you can configure them all on a different location.
could you explain in more detail? after that how would you run it without internet connection. just lan. like would steam launch cs go without a connection?
You need to launch steam in offline mod, then since you're on a local network you all can join the local server with his local IP
  • 2 weeks later...
6 hours ago, Aphala said:
Open your eyes
You didn't read what @Zando Bob said after quoting me
