$2000 itx gaming rig planning help
BDunkz
hello all,
I am planning an itx build for a friend, he an astounding $2000 to spend on it.
all he is doing really is gaming so he want the best itx gaming rig he can but he also want to show off so it has to look cool ether that or it has to be small, like console size
please give me some help
all thanks in advance
BDunkz
Cool, 2000$ should easily get him a GTX 1080ti and a Core i7 7700k.
please go on
what case?
Also, brace yourself. "GET A RYZEN!!!11!1"-comments incoming.
sorry I'm not familiar with amd (what is its intel equivalent?)
Just now, BDunkz said:
please go on
Wait a second friend:-) I'm going to need a second to post a pc part picker list
CPU: Intel - Core i7-6700K 4.0GHz Quad-Core Processor  ($309.99 @ SuperBiiz)
CPU Cooler: ID-COOLING - IS-60 53.6 CFM CPU Cooler  ($44.98 @ Newegg Marketplace)
Motherboard: ASRock - Z270M-ITX/ac Mini ITX LGA1151 Motherboard  ($118.49 @ SuperBiiz)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($104.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($87.88 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Asus - GeForce GTX 1080 Ti 11GB Turbo Video Card  ($669.99 @ Newegg)
Case: Silverstone - RVZ02B HTPC Case  ($69.99 @ Amazon)
Power Supply: Corsair - SF 600W 80+ Gold Certified Fully-Modular SFX Power Supply  ($119.25 @ OutletPC)
Total: $1574.00
Generated by PCPartPicker 2017-06-11 05:45 EDT-0400
Total: $1574.00
is there anything I can improve with the extra $400?
maybe a larger ssd and/or hdd, or a different case and cooler.
4 minutes ago, black0utm1rage said:
Win 10 Pro
What the difference from normal windows?
5 minutes ago, black0utm1rage said:
https://pcpartpicker.com/list/W28TgL
Core i7 7700k
16GB RAM
1TB SSD
Asus GTX 1080TI
Corsair H60
Fractal Nano S
750w Corsair PSU
Asus Z270 ITX Mainboard
Win 10 Pro
I'm just gonna use the other case I think coz it's smaller
Ok, that case is fine. But the rest of the other build is kind of inferior to what I proposed... If I were you I'd only interchange the case. And if you do, you'd also need to interchange the cpu cooler, because the case from the other build doesn't support a water-cooling unit. If you wanted me to I could do another build with a smaller case
Yes please the silver stone case that the other guy recommend
It would preferably be close to silent
Custom watercool an i7 7700K and a GTX 1080TI in a Phanteks Enthoo Evolv ITX. It wouldn't be the smallest system but it would look awesome!
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
Yeah, thats why I originally went with a slightly bigger case and a watercooler for an abundance of airflow and good cooling capability.
Could you get a parts list for me?
A Fractal Design Node 202 is a nice case, i have one and its great! Also supports full length GPU!
@BDunkz A custom watercooling loop would absolutely blow up your budget lol... Good quality components cost a fortune. A full loop might easily be 300-400$
If you don't know much about watercooling, don't watercool a PC for someone else.
Making a partslist is hard to say. EKWB has a custom loop configurator. https://www.ekwb.com/custom-loop-configurator/ You can enter your case, motherboard and GPU and follow the instructions.
Main PC:
Dorm PC:
NAS:
Laptop:
I've got a genrel idea on how to do it. Do you recommend ridged or soft tubing?
Yeah but @herman mcpootis made a build for less then 1600$ so he could get similar components (I personally would go for the i7 7700K because it overclocks higher and with a custom loop temperatures will be fine and I would get a 2TB HDD instead) and spend the rest of the budget on a custom loop. With this case (Phanteks Enthoo Evolv ITX) he has to replace the PSU with an ATX one like the EVGA Supernova G3 650W.
Main PC:
Dorm PC:
NAS:
Laptop:
Ok
Using soft tubing is easier but doesn't look that good in most cases.
Main PC:
Dorm PC:
NAS:
Laptop:
