I've got 1080 TI Xtreme Edition from Gigabyte and temps are extremely high. For instance, I leave fan at auto, and I overclock 125% to power and 50 to Core Voltage and temps go as high as 82-84C. What's wrong? Fans ramp up to like 77%.
I think this affects my clocks as it often stays at 2050Mhz and the longer I play the more it drops. Sometimes it settles in at 2025 etc.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/791453-1080-ti-high-temps/
125% TDP on the mediocre gigabyte cooler will give you high temps, although that shouldn't be above 80c.
maybe try to remount the cooler with new TIM?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9968913
shouldnt be that loud. my brother has a asus strix 1080 and on 40% fan speed it wont go over 70°C with a bit of overclocking
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9968916
3 minutes ago, Tiwaz said:
+ new clean thermal compound application, arctic mx-4 for example
Not sure if I want to void my warranty. Also, it is the best offering from Gigabyte. It's the Xtreme version with 150% power limit unlocked.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9968938
Xtreme or aurous?
Laptop:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9968953
Just now, RadiatingLight said:
Xtreme or aurous?
http://www.aorus.com/product-detail.php?p=170
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9968956
6 minutes ago, TheNaitsyrk said:
Damn. temps should be lower then.
maybe RMA the card? seems like a lot of hassle, but it might improve temps.
still though, the 1080Ti has a 250W TDP, and 50% more is 375W of power. That's a lot of heat for a small GPU cooler.
Laptop:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9968975
Small GPU cooler? This is 3 slot card.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9968986
my Founders 1080ti pushed that far (2050 Mhz) with 80% fan speed runs at 72C, something is not right for a cooler that large to require that fan speed. Look at the OC benchmarks from tech youtubers and see what temps they get, no card with fans that high should break 70ish
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9969045
They have it at 73C. I had 3 cards, and two of them did this. I RMA'd the previous 2.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9969059
5 minutes ago, Daniel644 said:
what is the airflow like in your case? do you have intake and exhaust fans?
It's fine believe me.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9969100
Nice setup! Have you seen how far the card will overclock at stock voltage? My founders is happy to run at 2025 albeit with a waterblock at stock voltage and from what I've read these cards don't necessarily react well to more voltage, it can often just make loads more heat. I'd be tempted to see how far you can overclock without any extra voltage and what the temps are like then. Do you have the gigabyte software installed as well as the nvidia drivers? I believe there is much greater control of the fans with the software installed and you can make sure that the card is running the right performance fan profile.
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9970099
MSI Afterburner works fine when it comes to fan control. I am actually not sure how far I can go on stock. Probably nothing to be honest, or maybe 20+ to core clock if lucky. Memory is not happy at all, if I give it 400, all games glitch like crazy and previous one could do 550 on memory somehow.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9970114
Fair enough, the only thing you could do is play around with the voltage/ frequency curve and a custom fan profile to see if you can get it running a bit better, otherwise it would have to be and RMA if you're not happy. 2025 is still a good overclock on air though and unless you only have it for benching then I wouldn't worry about 50 odd MHz. If you can reduce the voltage and have the card running much cooler and quieter, it really won't have much impact on frame rates. Did you see what it boosts to at stock voltage and the 20+ core?
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9970168
I'm about to find out now. It can run up to 2038 stable but temps are high.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9970174
This is when everything is cranked up. +50 core + 220 mem 100Mv 150% power limit
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9970215
3 minutes ago, offmyed said:
Yeah the temps do seem high for such a massive cooler, good luck with the results mate. I'm sure you already know but I would also find a way to lift your case up off the carpet, you'll be sucking in dust with it on the floor.
Here's a reading from Afterburner:
Fan speed 72% here.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9970221
Just now, offmyed said:
That's a good result for stock voltage, I would have a go with custom fan profiles to try and get the temps down, unfortunately these chips do run quite hot. What are your ambient temps?
This is not stock. This is all cracked up to max. Lmao, double check.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9970244
This is stock. Here's with just +20 to core clock. Temps are 76c.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9970249
Are you sure the voltage you are adding is +100 mv, the scale on the voltage is a % so you are just applying 100% voltage on the max overclock. I may be totally wrong but that's just how I read it. Have you done the registry tweaks to unlock the voltage?
Yes. Slider is at 100 as you can see in the previous screenshots. Voltage would otherwise be locked dude. 100Mv 150% power limit and +50 to core clock
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/791453-1080-ti-high-temps/#findComment-9970281
