Hey guys , i was wondering if some of you could give me some advice on the best budget/ silent/ performance fans ? I need 2 intake fans for the front of my case , it only gets airflow intake from the bottom and the top ( like in the picture) from the front of the case , should i get Static pressure fans ? like the corsair sp 120mm so they can push more air in those thight spaces ?
Note: It would be nice if they cost around 15-20 € (each)
Note2: i plan to plug my fans to 3 pin connectors thar are controlled by those switches you can see on top of the case , each switch controlls 2 fans.
https://linustechtips.com/topic/791448-need-fan-reccomendation/
15-20€ each or together?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/791448-need-fan-reccomendation/#findComment-9969072
What about be quiet! Silent Wings 3 PWM?
Or something from Noctua?
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/791448-need-fan-reccomendation/#findComment-9969232
Noctua are kinda ugly xD and the black version is quite expensive ...
Are the be quiet! Ones efficient tho ?
Oh and i plan to connect them to  3pin connectors that are controlled by those 2 switches you can see on top of the case . Each switch controlls 2 fans.
https://linustechtips.com/topic/791448-need-fan-reccomendation/#findComment-9969897
the be quiet! ones are too expensive... 30 € that's too much :C
https://www.amazon.es/quiet-SilentWings-PWM-Carcasa-ordenador/dp/B01JME13SW/ref=sr_1_1?ie=UTF8&qid=1497177987&sr=8-1&keywords=be+quiet!+Silent+Wings+3+PWM
https://linustechtips.com/topic/791448-need-fan-reccomendation/#findComment-9971998
2 minutes ago, Cazan said:
Oh, they cost less then 20€ where I live. xD
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/791448-need-fan-reccomendation/#findComment-9972007
8 minutes ago, Cazan said:
sorry then ... i think i'm going for the noctua nf-p12 ! what do you think ?good?
They are made by Noctua. Of course they are good! :D
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/791448-need-fan-reccomendation/#findComment-9972044
No problem! Noctua fans are a bit expensive but they are very quiet.
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/791448-need-fan-reccomendation/#findComment-9972049
2 minutes ago, GrayTech said:
No problem!
oh and good luck with that ryzen build ! i got the same ram , same cpu and same mobo brand eheh you are going to be very happy with that !dont forget to update bios and get the ryzen balanced power plan :) even got the same psu brand xD
https://linustechtips.com/topic/791448-need-fan-reccomendation/#findComment-9972054
Thanks! My parts will probably arrive tomorrow!
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/791448-need-fan-reccomendation/#findComment-9972056
