So after the calamities I had with my Ryzen chips, I've still got a spare chip lying around, and can't seem to budge it even after trying to sell it, so I've decided to make a small form factor build out of it! With my current rig going to be upgraded to a 1080 GPU, it means that my current RX480 will be spare, so I've already got a GPU and CPU, along with the default Wraith Spire cooler (although I might upgrade it).
My idea is that this machine could become a dedicated rendering machine or could be used as a family gaming machine, so I want it to be small, discrete and not too large as to fit in small spaces!
This is a current build I have put together, with a small ATX board and case, but any improvements would be greatly appreciated, as money isn't really too much of an issue for me!
https://uk.pcpartpicker.com/list/HKwPWX
https://linustechtips.com/topic/791272-small-form-factor-ryzen-7-build/
if you really want it to be small you might want to get an ITX board and case instead.
https://uk.pcpartpicker.com/product/JRPzK8/biostar-x370gtn-mini-itx-am4-motherboard-x370gtn
right now this is the only one available on pcpartpicker tough.
You should've gotten the 580 :/ Also, an SSD will help.
I would have, but my original build was done around 2 months before they released them sadly! Yeah I think a SSD is a good option, even if it is only a boot drive.
meh, the 580 is pretty much just an overclocked 480 anyways, just oc the 480 and it shouldn't perform much different from the 580.
made it much smaller:
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  (Purchased For £320.00)
Motherboard: Biostar - X370GTN Mini ITX AM4 Motherboard  (£99.99 @ Ebuyer) or wait for other itx boards from asrock and other companies.
Memory: Kingston - Savage 8GB (1 x 8GB) DDR4-2400 Memory  (£51.50 @ CCL Computers)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.99 @ Aria PC) add in an ssd if you can.
Video Card: Asus - Radeon RX 480 8GB Dual OC Video Card  (Purchased For £175.00)
Case: Silverstone - Sugo SG13B Mini ITX Tower Case  (£39.78 @ Amazon UK)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£48.36 @ Ebuyer)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  (£23.00)
Total: £795.62
Generated by PCPartPicker 2017-06-10 11:20 BST+0100
Yeah, SSD for Windows and the 1TB for storage. :)
Total: £795.62
That case is stunning too! Really like the look of that one :)
