No voice on discord - Network problem?
Squanchy
Hey all,
I just got a new router and I can't seem to talk on discord... I can hear people but my voice cannot be heard. This is on a wired connection, when i go to wireless I can talk perfectly fine.. My old router(e2500) I could just fine, but with my new router(Nighthawk 6700) I cannot with ethernet..
Any ideas? My firewall is open for discord. Specific setting in the router i'm missing?
So, the old one worked but the new one doesn't.  Hummmmm......  go back to using the old one.
Old one is dying. Hence why I got a new one. However I just found out that it doesn't work with the killer lan port, but it works with the intel lan port... hmm
3 hours ago, Atreyix said:
Sounds dumb, but I had the same problem and it worked for me, close it and run as administrator.
hi
