What cable to use?
Go to solution Solved by Enderman,
4 minutes ago, JoeR said:
I know but I came here asking for help and I just end up getting roasted. Also, Minecraft is amazing I played it a few hours ago lol. My friends and I haven't played it for over a year and we were bored and started playing
We joke around on the forum all the time, don't take it personally.
Displayport 1.4 will do 4k 144Hz, but apparently there needs to be some Display Stream Compression https://en.wikipedia.org/wiki/DisplayPort
Your 1080 is DP1.4, and I assume your monitor is too if it is 4k 144Hz, so just get a good quality cable for DP1.4
Also get ready to turn down settings a lot in the games you play.
You might also notice my username is 100% minecraft :)
probably displayport
which monitor?
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/791163-what-cable-to-use/#findComment-9966214
8 minutes ago, Abyssal Radon said:
4K 144hz monitor? What monitor do you have and I would use display port cable. Also good luck running games at 144hz at 4K... with a 1080.
Maybe he only plays minecraft? :P
https://linustechtips.com/topic/791163-what-cable-to-use/#findComment-9966221
3 minutes ago, JoeR said:
Thanks for treating me like an idiot, I clearly didn't know something you knew, and that makes you better than me right? We all have to learn somewhere along the line.
Wow dude, chill, it's a joke.
I play minecraft, it's a great game, nothing wrong with that.
https://linustechtips.com/topic/791163-what-cable-to-use/#findComment-9966252
https://linustechtips.com/topic/791163-what-cable-to-use/#findComment-9966263
https://linustechtips.com/topic/791163-what-cable-to-use/#findComment-9966275
