I don't think they have 4K 144Hz IPS panels out yet, so you may have to settle with a TN.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/790613-best-current-27-display/#findComment-9959997
3 minutes ago, BlackUnicornGaming said:
I am probably gonna go dual 1080ti
The only one I heard of is the predator x27. I don't think it's out yet or if they have any out.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/790613-best-current-27-display/#findComment-9960008
how is he even gonna power that, the latest Display Port can handle 4k 60hz per connector, so with dual display port he can run 120hz 4k at best i assume
https://linustechtips.com/topic/790613-best-current-27-display/#findComment-9960017
14 minutes ago, BlackUnicornGaming said:
I have a cheaper budget. I am wondering currently what is the best 144hz 4k display out there that is 27"
There are no 144 Hz 4K monitors out at the moment. Also you are basically asking for a "budget Lamborghini", it's contradictory request, at least currently.
https://linustechtips.com/topic/790613-best-current-27-display/#findComment-9960041
How about that part where I said budget? HAHA
Budget, 4k and 120+ Hz are not terms that go together at this moment (budget and performance in general for that matter). Also if you're going dual 1080 Ti I think you can spend a bit more on a screen... :P Otherwise sacrifice one card and get a better screen I'd say.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/790613-best-current-27-display/#findComment-9960050
jusr get a 1440p 60 hz for christ sake with a single 1080 i dont see the point in 4k with higher than 60hz anyway and sinceu were asking for high resfresh rates you arep robably not a content creator
https://linustechtips.com/topic/790613-best-current-27-display/#findComment-9960051
Pretty sure he is just being a troll. He could've googled it and he obviously knows its not a low budget monitor.
https://linustechtips.com/topic/790613-best-current-27-display/#findComment-9960060
