Building this for a friend.
Budget is $1000, but I can go over by like $25 (as I have done)
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($209.99 @ Amazon)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($65.98 @ Newegg)
Memory: G.Skill - Flare X 16GB (2 x 8GB) DDR4-2400 Memory  ($106.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($87.88 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Zotac - GeForce GTX 1070 8GB Mini Video Card  ($334.45 @ Amazon)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($46.99 @ Amazon)
Other: In Win 301 Tempered Glass Premium Micro-ATX Mini-ITX Tower Gaming Computer Case Cases 301 White  ($69.99 @ Amazon)
Other: Windows 10 ($35.00)
Other: Fans ($20.00??)
Total: $1025.71
Generated by PCPartPicker 2017-06-06 05:10 EDT-0400
Anything You'd change about the build?
What fans should I buy? the In-Win 301 comes with no fans, so obviously I need some. Probably static pressure fans as well. which are the best (I want at least 2 fans).
Also, I need a monitor for this. Maybe something 1080p ultrawide?
My friend's dad works at Samsung, so he can get a deep discount on any Samsung monitors, so it's probably best to pick him a Samsung monitor, simply for cost savings. (this also goes for Samsung SSDs and stuff in the actual build)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/789475-final-build-check/
Total: $1025.71
I have a few comments, but its up to you, just my personal opinion.
A- get an rx 580 8gb
B- get a better psu
then spend the saved money on a better mobo, from a manufacturer like msi (b350 gaming pro?)
-Lukas
1000$ PC: CPU:AMD Ryzen 5 1600 @3.6ghz Motherboard: Gigabyte AB350 Gaming-3 RAM: 16gb Corsair Vengeance 3000mhz GPU: Gigabyte GTX 1060 6gb G1 gaming Storage: 2tb Seagate Barracuda 7200rpm PSU: Corsair Vengeance 550m Case: NZXT S340 Black/Red Keyboard: Corsair Strafe w/ cherry mx browns Mouse: Steelseries Sensei 310
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946231
1 minute ago, tom_w141 said:
@RadiatingLight
When you have bought a couple fans isn't it more expensive than a P400 TG? Also the main In win turn off for me is the huge branding on every case
It's $70, so if the fans cost $20, it is a bit more expensive. however, the motherboard is a real cost-saver. it's gross to put an mATX board in an ATX case, so if I go with the P400 TG, i have to go with the cheapest ATX board, which is about $25 more expensive.
so overall I save $10 if I assume fans cost $20. I'm hoping I can get some fans for cheaper, so then maybe I can save even more money.
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946233
I would pick a PSU with more capacity. It won't go past the 450w rating, but it's close.
Also, if you don't mind using the SSD solely as a boot drive, then a 128GB one will save money for an ATX board, which carries more expansion slots for further upgrade in the future
Desktop benching:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946237
B- get a better psu
-Lukas
A- Why
B- If it is the 2015 version (black label) all is good.
C- No improvement in performance with a better mobo and it is not like they will be putting it under LN2 or doing SLI.
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946240
Get a pc for corsair fans. ML120 or 140s or something like that.
Build
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946243
B- get a better psu
-Lukas
The whole point is that I'm trying to fit in a GTX 1070. I'd be a cake-walk if I had $100 extra from downgrading the GPU.
The PSU is fine. Tier 3 is definitely good enough, and the wattage is more than needed.
The motherboard is really not great, but I'd much rather have a low-end mobo, than have a 30% worse GPU.
In fact, I'd rather downgrade the CPU to a 1400 or 1500X before I'd downgrade the GPU.
Not to say that I'm just throwing your feedback out the window though. I do consider all feedback given to me.
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946245
get a better mobo. it's not that much more expensivc - the ab350m is absolute trash for everything and doesn't let you get the best of the Ryzen platform's features.
it's a A320 mobo with a B350 chipset on it.  it doesn't even support 95W CPUs FFS
idk
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946254
Ideally, I want to make as little compromise as possible, So I'll try to hang on to the bigger SSD unless my friend really wants it to be under $1000, but it's the first thing to get chopped if the price is too high.
the PSU won't reach anywhere near 450W. I have a 4770K (more power-hungry) and a GTX 1070, and my PC barely draws 300-350W from the wall under full load. bearing in mind the 80% efficiency of my PSU, and my 1070 + 4770K take barely more than 300W. 450W is fine.
The case is mATX. I chose this for a reason -- cost savings. it will look okay in an mATX case, and it's significantly cheaper.
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946256
That's the HDV version, which only has two phases. this is the non-HDV version, so it has three phases (and is cheaper?), letting it supply up to 95W. it's not a great OCer, but it should be enough to get a 1600 up to 3.8Ghz or so, which is really all I'm expecting.
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946267
4 minutes ago, RaptorCandy said:
Why spend so much on a motherboard. that's $40 extra.
In this case, I spend $30 more, and get:
- Better Motherboard
- Worse SSD
- Case with no Tempered Glass
IMO, the better motherboard doesn't outweigh the other drawbacks, and it's starting to really push the budget, and tempered glass is really cool, and it's something that I'd prefer to be part of the build.
However, you don't need to include the $15 fans on that list, since the S340 comes with fans.
very good build though, I will take parts of it into consideration.
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946275
oh shit, forgot.
eh, still not a fan of AsRock's low end boards - IMHO the Pro4 is the minimum for me, which also has 3 but top VRM cooling as well.
idk
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946276
oh shit, forgot.
It ain't ideal, but it will work.
and the non-HDV model does have an, albeit small, but still present, VRM heatsink.
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946281
Drop to a 128gb sdd.
Build
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946290
I'm considering it...
but so far, I don't need to lower the cost, so I'll keep the larger SSD
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946296
@DeezNoNos @Droidbot
What about fans?
ML fans are expensive.
I want two fans for $20 max... Anything good in that pricerange?
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946305
the Seasonic M1211 Evo is for $55. Just get that extra $10 and be with a higher wattage psu
Build
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946306
What about fans?
Get the older corsair one. SF120/140 or AF120/140
Build
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946308
SP120s seem promising.
But still a bit too expensive.
I know it's hard recommending shitty fans, but I'd really like 2 for $20 or less.
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946319
To be clear, if there are no good fans under the $27 for a two-pack of SP120s, then I'll get those.
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946321
Go to a send hand store and pic up some fans. CHEAP.
Build
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946339
Eh. I'll just get the SP120s then.
Thanks for your help.
Laptop:
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946346
Arctic F12 PWM or Pure Wings 2 maybe
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/789475-final-build-check/#findComment-9946348
