I am attempting to overclock my cpu (intel G3258) and I overclocked it to 3600MHz with manual voltage of 1V. The problem I am having is with using offset mode, I want to use offset mode or auto so that the voltage will decrease when idling, but looking on CPU-Z and HWMonitor the voltage is fixed on 1.174V.
CPU: Intel Pentium G3258 (Stock Cooler)
Motherboard: H81M-A w/ BIOS 2203
OS: Win10
PSU: Corsair CX430w
GPU R7 260x - GPU clock: 1815 - MEM clock: 1485
RAM: 8GB running at 1400MHz
https://linustechtips.com/topic/789441-overclocking-voltage-problems/
3 minutes ago, tp95112 said:
Decreasing voltage tends to cause a lot of instability. I wouldn't worry to much about it being at constant voltage all the time.
Oh right, I wanted the voltage to decrease with the core clock so temps and power consumption would be lower but if I was to just leave it on manual at 1V, it should be fine?
You are doing it wrong.
Use manual voltage instead of offset. The volts will still drop on idle as long as all the C-states and EIST are enabled in BIOS.
CPU-Z may bug out and still show only maximum voltage so check statistics in Aida64.
It is normal for voltage to go a bit above what you set when stress testing it.
