Macbook Pro Retina Display Battery Question
Solved by atrash,
it uses AC power when plugged in. and keeping it plugged in even when the battery full is fine. you don't have to worry about wearing the battery down. remember to use the original provided power adpter. just don't drain the battery to less than 20% or operate the laptop in high ambient temperature.
Featured Topics
aisle9 ·
Posted in Peripherals0 -
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
2
6
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
