Hello All,
I'm replacing my Mobo but that means replacing my CPU, RAM, and Getting a New OS. I've been researching but there are problems with everything I want for my criteria. I mainly use my PC for gaming so a quad core is a good bet. However, Intel's i5 seems too pricey in its last two generations. As for Ryzen I don't know enough about the differences about the 1400 and 1500X but they seem to have a good price, however I don't know much about AMD boards (is it just like Intel with the X and B in front just meaning OC or not, if so which should I go with) to know what to get. I also don't know if my CPU fan would work for AM4 (I have a CM V8 or something like that).
For the Motherboard, I'd like to go ASUS but that isn't set in stone.
As for RAM, I don't know what speed to go with and when I looked at differences so many prices didn't seem to make sense for what I would be getting. And for SSD I really don't have a preferance.
Anyway, could someone help me out with this and recommend what I should do.
Thanks.
https://linustechtips.com/topic/788789-build-questions/
Go for a ryzen 1400. The x variants aren't really worth it.  You can overclock either way. Get a b350 board doesn't matter which one. Don't buy a motherboard based off brand just based on the features you want.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/788789-build-questions/#findComment-9937318
You should get a Ryzen 5 1600 with an ASUS B350 motherboard and 3000MHz RAM(preferably with Samsung B-dies). The 1600 is definitely worth the $30 more than the 1500X ;)
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/788789-build-questions/#findComment-9937329
The X and B series chipsets on AMD'S site can OC yea, I would choose a board with an X series chipset, you get more PCIe lanes and USB port support. The 1500x is clocked a bit higher than the 1400.
(http://www.cpu-world.com/Compare/570/AMD_Ryzen_5_1400_vs_AMD_Ryzen_5_1500X.html)
also could you be a little more specific on your cooler? :) most manufactures include an AM4 bracked.
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/788789-build-questions/#findComment-9937330
850 Evo is good for an ssd. I would reccommend getting something 256GB and over. You can get windows cheap on kinguin or g2a.
https://linustechtips.com/topic/788789-build-questions/#findComment-9937360
http://www.coolermaster.com/cooling/cpu-air-cooler/v8-gts/
Thanks for responding! the link above is my cooler.
https://linustechtips.com/topic/788789-build-questions/#findComment-9937427
8 minutes ago, Blackhole890 said:
budget? location? for what are you using for?
I'd like to not spend more than 500 but that is partially negotiable, South Western U.S. ,I'd like to use it for gaming but I need it to do general work as well like interface via a wired/wireless network with other PCs. Thanks for the quick reply!
https://linustechtips.com/topic/788789-build-questions/#findComment-9937458
Thanks! I'll start looking
https://linustechtips.com/topic/788789-build-questions/#findComment-9937496
1 minute ago, Drew Learns Tech said:
That is strange its LGA 1151 compatible it should be AM4 compatible or is it for a different reason?
i think that they havent designed a bracked for am4 support, try searching to make sure that there is not
@deXxterlab97
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/788789-build-questions/#findComment-9937502
1 hour ago, Drew Learns Tech said:
Is either of them reputable and reliable?
I would get buyers protection (the shield option at checkout) because some of the keys they get from the sellers aren't always on the up and up. If windows doesn't activate with it you can get another with the shield.
https://linustechtips.com/topic/788789-build-questions/#findComment-9938444
https://pcpartpicker.com/list/bxHKVY. It probably uses an LGA backplate. The am4 backplate is different and is probably the reason pcpartpicker marks it as not compatible.
https://linustechtips.com/topic/788789-build-questions/#findComment-9938486
I'm just wary because pc part picker said the same thing about my case but it fits fine
https://linustechtips.com/topic/788789-build-questions/#findComment-9938503
Case clearance is harder to measure I guess. I am 100% sure it won't work unless you can get the proper upgrade kit.
 http://www.pcgamer.com/cooler-master-is-taking-reservations-on-free-am4-cooler-upgrade-kits/
https://linustechtips.com/topic/788789-build-questions/#findComment-9938523
2 minutes ago, Stevoisboss said:
Case clearance is harder to measure I guess. I am 100% sure it won't work unless you can get a different backplate.
Okay Thanks a ton
https://linustechtips.com/topic/788789-build-questions/#findComment-9938540
