Website Creation Help
Go to solution Solved by tp95112,
2 minutes ago, ziloflow said:
thanks bro, is this how this website was made???
I  believe they use VBulletin and built on it themselves
This website is actually built upon IPB(v4)/the IPS community suite. Hence the 'Community Software by Invision Power Services, Inc.' at the bottom of the page.
https://linustechtips.com/topic/788365-website-creation-help/#findComment-9932320
well, being a developer myself I can say that first thing you need is solid html, css and JS skills to create the UI
on that you might require a scripting and backend like JS, PHP, python, Java, etc
last you need to create a DB. you can use either of these: mysql or PGSql
if you want to make things more fancy, and scale the platform you may use redis to cache your DB query and results, mongoDB or other no-sql platforms backend caching or running as back-up while your original DB is under maintainance.
later you need a server to run the site on. I recommend Digital Ocean / AWS / Google cloud for VPS solution. but please go with a reliable VPS solution. Some other basic stuff to handle VPS would be :
1. should know how to operate on bash shell and linux
2. installing packages (its quite simple these days)
3. install configure your apache/nginx server
4. installing DB engine
5. installing backend services like PHP/Python/Ruby .. (depends on what you are using)
https://linustechtips.com/topic/788365-website-creation-help/#findComment-9934279
