Yes it's good
What's your specs?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/788127-corsair-power-supply/#findComment-9929612
1 hour ago, Richard N. said:
https://pcpartpicker.com/list/HPDhNN i have ordered everything except the motherboard and ram.
The mobo isn't good due to poor overclocking potential (only supports 65W TDP CPU)
HDD too small
Desktop specs:
https://linustechtips.com/topic/788127-corsair-power-supply/#findComment-9929806
2 hours ago, Daniel Z. said:
if has a grey label yes
All CX 450/550/650 (Great Wall; unnamed) and 450M/550M/650M (CWT; "Corsair Vengeance") have Gray labels.
CX 750 (Green Labelled: CWT; PUQ-B, Gray Labelled: Greatwall; unnamed) and 750M/850M (All CWT; PUQ-B) have green and Gray labelled versions, but either are good anyway.
CX 430/500/600/430M/500M/600M (CWT; DSA Series) will always have green labels.
CX 400 (Seasonic; ET) have no label, but you can essentially ignore them since they have been disconnected for 7 or so years. But they are okay units.
Asking what colour label is annoying and confusing. Please stop.
https://linustechtips.com/topic/788127-corsair-power-supply/#findComment-9929861
jeez ok chill
https://linustechtips.com/topic/788127-corsair-power-supply/#findComment-9930537
8 hours ago, Richard N. said:
elaborate on questionable
Most HDDs of that capacity are painfully slow. Yours is no exception.
I'm going to go through all of the things that are wrong with this system and offer you a better parts list.
That CPU is fine, however the motherboard has terrible power delivery and I'd stay away from it. Having tried to use an i7 4770S on my B85M-DS3H which had a garbage power phase design that would throttle the CPU clock speed even when the CPU wasn't under tremendous load, I'd recommend you get something with, at the very least, a VRM heatsink.
You can spend less on an 8GB stick of memory.
You have a 250GB HDD and no SSD, nor enough storage to do much with. That hard drive you chose is going to be so painfully slow you'll want to tear your hair out when your brand-new PC is outpaced by a moderately cheap laptop.
You have a GTX 1070 and yet a tiny case with only one case fan for airflow, which will make your 1070 remarkably hot.
Your PSU is fine and should power a 1070 and 1600 with room to OC, but you probably could have gotten something with more output and not a sleeve-bearing fan. You focused all of your money on the 1600 and 1070 with no other hardware to support them. It's like buying a Lamborghini and then getting the cheapest insurance you can to cover it.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($209.99 @ Amazon)
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard  ($78.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory  ($58.99 @ Newegg)
Storage: PNY - CS1311 120GB 2.5" Solid State Drive  ($52.99 @ Best Buy)
Storage: Western Digital - RE3 1TB 3.5" 7200RPM Internal Hard Drive  ($41.99 @ Amazon)
Video Card: Asus - GeForce GTX 1070 8GB Video Card  ($367.57 @ Amazon)
Case: Cooler Master - N200 MicroATX Mini Tower Case  ($31.98 @ Newegg)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($46.99 @ Amazon)
Total: $889.49
Generated by PCPartPicker 2017-06-03 12:41 EDT-0400
https://linustechtips.com/topic/788127-corsair-power-supply/#findComment-9931065
Total: $889.49
im sorry to say but so far ive bought everything except the motherboard and ram which i will change. At the moment i have 257 dollars to spend on a motherboard, 8gb of ram and an ssd and i will buy case fans if thats ok
https://linustechtips.com/topic/788127-corsair-power-supply/#findComment-9932063
Total: $889.49
https://pcpartpicker.com/list/L3yZ3F how about this since i havent bought ram, MOBO, or ssd yet and i need fans?
https://linustechtips.com/topic/788127-corsair-power-supply/#findComment-9932117
Should work fine but if you're stuck with the Thermaltake case I'm not sure it even supports that many fans or if you need that many.
https://linustechtips.com/topic/788127-corsair-power-supply/#findComment-9932179
http://www.thermaltake.com.au/products-model.aspx?id=C_00002584 it actually supports 5 fans total however im only going to be buying 3 b/c it comes with one.
https://linustechtips.com/topic/788127-corsair-power-supply/#findComment-9937981
