My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/788047-will-the-cooler-fit/
1 minute ago, Ahaber said:
probably. look on manufactures website to see if they list a maximum cooler height I would probably be most worried about memory clearance.
thats what im worried about too.
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928586
The maximum cooler height is 60mm and my case supports 60 mm. Should i be worried.
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928591
If the red slots are the ones that they would go into you should be fine if it is the black ones then they might not fit. The motherboard manual will tell you which ones should be populated first 60 mm is really short are you sure that is correct?
:)xD9_9:D:PB|
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928595
I mean height wise.
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928597
why get a cooler at all ? drop it drop the 2 fans get a cheap copy of windows off like kingquin and get a 1070
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928605
The cooler is 160 mm tall
Oops. Im very sorry. The case support a160mm height.
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928606
If you aren't planning to overclock you definitely do not need a cooler this big also.
Futureproofing?
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928610
and quietness.
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928612
I want good airflow. My dads buying the parts and he wont buy it off of kinguin.
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928615
Then go liquid cooling
That's very expensive, plus liquid coolers can leak.
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928617
2 minutes ago, Vandorlot said:
and quietness.
the stock cooler with ryzen is really quiet already i dont hear it at all
Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928618
im worried that it will overheat.
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928621
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928623
its not gonna overheat the spire is a great stock cooler
Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928624
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928628
120 mm is going to be better than a stock cooler. I guess I don't really understand what you want.
sorry.
My Rig
 Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928640
For just 50$ more you could drop the cooler the 2 fans there not gonna make your pc that much quieter and get a 1070 this would be alot better
spend the extra money on useful stuff
you could also get a cheaper pc case the glass is gonna me it a littl louder
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (Purchased For $207.00)
Motherboard: Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard  (Purchased For $80.00)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory  (Purchased For $103.00)
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive  (Purchased For $220.00)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Asus - GeForce GTX 1070 8GB Dual Series Video Card  ($373.98 @ Newegg)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  (Purchased For $90.00)
Power Supply: SeaSonic - M12II 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  (Purchased For $39.99)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Monitor: LG - 29UM67P 29.0" 2560x1080 60Hz Monitor  (Purchased For $250.00)
Headphones: Kingston - HyperX Cloud Stinger  Headset  ($49.99 @ Amazon)
Total: $1552.29
Generated by PCPartPicker 2017-06-02 21:57 EDT-0400
Peripherals
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928652
Dont get a AiO if not OC'ing (Especially a cheap one, high end air is better), just get a single tower cooler if worried about noise.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/788047-will-the-cooler-fit/#findComment-9928653
