Intel Core i5 6600K
32GB Crucial 16GB Kit (8GBx2) DDR4 2133 MT/s (PC4-17000) CL15 DR x8 Non-ECC UDIMM 288-Pin Memory CT2K8G4DFD8213/CT2C8G4DFD8213
6 Western Digital Gold 10TB Datacenter Hard Disk Drive Class SATA 6 Gb/s 7200 RPM 256MB Cache 3.5-Inch Form Factor (WD101KRYZ)
ASUS P10S-M WS Motherboard
Intel Ethernet Converged Network Adapter X540-T2 10GBASE-T Dual Port
Rosewill 4U Server Chassis / Server Case / Rackmount Case, Metal Rack Mount Computer Case with 12 Hot Swap Bays & 5 Fans Pre-Installed (RSV-L4412)
CableDeconn High Speed 6Gbps 4pcs/set Sata Cable Sas Cable for Server 1M
Had to swap out the power supply because there were not enough Molex ports on the non-modular PSU.
Going to do a RockStor install.
"Cheapness is not a skill"
https://linustechtips.com/topic/787993-nas-project/
was planning on buying some WD golds for my
pc (no nas, need a really reliable HDD)
seems like they've changed how Their drives look lol
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/787993-nas-project/#findComment-9927956
what RAID you going to be using???
This just for home use or for business???
Guessing the green PCB is a m.2 SSD for a SSD cache. What size is it???
Also how many people are you expecting to be hitting this server at one time???
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/787993-nas-project/#findComment-9927959
looks like it, that being said they are great HDDs so you can forgive the looks of them
https://linustechtips.com/topic/787993-nas-project/#findComment-9927971
I think it looks great TBH lol
expensive though, I might go Seagate. Money is a problem :/ and I want reliability also
https://linustechtips.com/topic/787993-nas-project/#findComment-9928059
I have owned both seagate and WD and have never had a drive from either of them fail. So far as I am concerned both of them make very reliable drives
https://linustechtips.com/topic/787993-nas-project/#findComment-9928061
Not as in Seagate is worse than wd
i mean it'll run for at least a few years without fucking up. All of my drives have died relatively quickly (~1-3 years)
https://linustechtips.com/topic/787993-nas-project/#findComment-9928070
I have drives which are a good 6-7 years old now which are running perfectly
https://linustechtips.com/topic/787993-nas-project/#findComment-9928074
I have a wd black that's on its last leg (2008), and another from 2009 that died a few months ago. Then again that was on its last leg aswel.
I had a 3tb WD green and that died (2012-2017) and a 2tb one (2011, isn't powered on as it stores my really important stuff; is in a drawer lol)
https://linustechtips.com/topic/787993-nas-project/#findComment-9928078
fair enough. I recently acquired a WD1500ADFD (it's one of those old clicky hard drives, and is using either SATA or SATA 2 (dunno which one is beings used on this drive) which was bought in 2007 I think and is still going strong. That being I anit using it as the click can get annoying and also it's only 150GB so there's issues of it can store an OS, and possibly only a few applications (depending on what applications)
https://linustechtips.com/topic/787993-nas-project/#findComment-9928104
I am not sure what RAID to use.  RAID 6 more than likely.  I have been reading about ZFS and maybe will try that.
This is for biz archive server
using a "Transcend 32 GB SATA III 6Gb/s MTS600 60 mm M.2 SSD Solid State Drive TS32GMTS600" from Amazon for the RockStor OS.  I may run the OS on a usb, because if m.2 is enabled then i lose the 8th sata port.  but now it isn't an issue.
this is more machine to machine connections for large file transfers.
https://linustechtips.com/topic/787993-nas-project/#findComment-9943685
WD has always been my drive of choice.  but i have had every color pretty much fail on my except these gold drives which I have never used yet.
WD Green & Blue I've had lots of failures.
WD Black not too many but some.
WD Red only 2.
https://linustechtips.com/topic/787993-nas-project/#findComment-9943704
they are pretty ugly compared to their Seagate counter parts.  but some dig the monolithic look.
https://linustechtips.com/topic/787993-nas-project/#findComment-9943717
sounds fun. Yea the disabling of SATA ports can be a pain in the arse at times when your trying to do something like this.
WD Red only 2.
Yea I have been lucky with drives and never had any fail, that's touch and go though, and I hope that stays like that.
Yea I can see why some people do I just don't think they look the nicest. That being said I have never had one fail on me, and when they do, it's normally due to them being used for too long and it's (normally) expected or it's due to an environmental reason rather than the drives themselves
https://linustechtips.com/topic/787993-nas-project/#findComment-9944031
the power supply comes today so I haven't even spun up the golds yet. :(
hope it goes well and it actually works. You dinny want anything to be broke before you even start.
https://linustechtips.com/topic/787993-nas-project/#findComment-9944038
Beautiful... if only the currency conversion didn't make those drives prohibitively expensive they would be my choice for an upgrade
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/787993-nas-project/#findComment-9956860
