First Build: Two options + suggestions
Go to solution Solved by Gansters12,
After some shuffling...here's what I have come up with.
PCPartPicker part list: https://pcpartpicker.com/list/sxNsFd
Price breakdown by merchant: https://pcpartpicker.com/list/sxNsFd/by_merchant/
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($299.89 @ OutletPC)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($138.98 @ Newegg)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($114.99 @ Newegg)
Storage: Western Digital - Blue 500GB M.2-2280 Solid State Drive  ($149.94 @ OutletPC)
Video Card: Zotac - GeForce GTX 1080 Ti 11GB AMP Edition Video Card  ($699.00 @ Amazon)
Case: Phanteks - Enthoo Evolv ATX Glass ATX Mid Tower Case  ($179.99 @ Amazon)
Power Supply: BitFenix - Whisper M 450W 80+ Gold Certified Fully-Modular ATX Power Supply  ($66.99 @ SuperBiiz)
Monitor: Dell - S2417DG 23.8" 2560x1440 165Hz Monitor  ($399.00 @ Adorama)
Keyboard: Cougar - 200K Wired Gaming Keyboard  ($34.90 @ Amazon)
Mouse: Logitech - G403 Prodigy Wireless Optical Mouse  ($99.99 @ Best Buy)
Total: $2183.67
I think this is an excellent improvement...the cpu & gpu are better and I keep the monitor/case I want without any real sacrifices. Let me know your thoughts! Also, thanks for the help!!
Hi there, I'm doing my first build and I'd like to be around the $2000 range. I have setup two possible options and would like everyones input on a few items.
Build Goals:
1440p @ ~144Hz
NO case compromise
Relatively silent
Prefer chiclet keyboard & selected mouse
Potential questions:
RAM
       -speed vs. latency
       -more channels better?
Ryzen vs Intel cpu and mobo?
       - more threads?
       - Ryzen better in future?
Liquid vs Air cooling
       - Which is quieter/better temps?
       - GIANT heat spreader vs. rad?
Option 1:
PCPartPicker part list: https://pcpartpicker.com/list/dBKsFd
Price breakdown by merchant: https://pcpartpicker.com/list/dBKsFd/by_merchant/
CPU: Intel - Core i5-7600K 3.8GHz Quad-Core Processor  ($228.49 @ OutletPC)
CPU Cooler: Corsair - H55 57.0 CFM Liquid CPU Cooler  ($59.88 @ OutletPC)
Motherboard: Asus - STRIX Z270-E GAMING ATX LGA1151 Motherboard  ($189.99 @ Amazon)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($149.99 @ Newegg)
Storage: Samsung - 850 EVO 500GB M.2-2280 Solid State Drive  ($184.99 @ Amazon)
Video Card: Asus - GeForce GTX 1080 8GB TURBO Video Card  ($509.99 @ SuperBiiz)
Case: Phanteks - Enthoo Evolv ATX Glass ATX Mid Tower Case  ($170.99 @ Amazon)
Power Supply: SeaSonic - 520W 80+ Platinum Certified Fully-Modular Fanless ATX Power Supply  ($129.99 @ NCIX US)
Mouse: Logitech - G403 Prodigy Wireless Optical Mouse  ($99.99 @ Amazon)
Total: $2158.20
Option 2:
PCPartPicker part list: https://pcpartpicker.com/list/kQmNHN
Price breakdown by merchant: https://pcpartpicker.com/list/kQmNHN/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($215.98 @ PCM)
Memory: G.Skill - Value 16GB (4 x 4GB) DDR4-2133 Memory  ($141.42 @ Amazon)
Total: $2086.11
*Also, would it be worth it just to get a 1080 Ti?
https://linustechtips.com/topic/787844-first-build-two-options-suggestions/
1. Liquid vs Air, air is cooler no doubt
2. That looks like an awful way of spending stuff. First off you have a 120mm cooler H55 which is significantly louder than 240/360mm cooler
Secondly, Asus Turbo is a blower style card, it is also loud and hot. IT seems like you are going against silent build
Third, a fanless PSU is quiet but most Seasonic PSU are already silent even with fans and some can run fanless mode, save money too
Fourth that looks like a very cheap keyboard paired with a very expensive mouse. I would never buy a keyboard that's cheaper than a mouse
Fifth, 850 Evo is a bad value as they cost too much
Sixth, If you go with Ryzen look for 3000 Mhz and up memory modules, it has been shown to improve performance by few percent more
Eighth, both Intel Kaby Lake and Ryzen only supports maximum of 2 channels so basically a kit of 2 RAM or 4 RAM sticks is good but odd numbers like 1 and 3 won't work. The benefit of Single channel and Dual channel isn't huge but well it is prettier to have 2 RAM sticks in a build vs just 1.
Ninth, Get a 1080 Ti if you play extremely demanding games.
Tenth, Ryzen 7 would suit you better if you do streaming and gaming at the same time. An i7 7700k is what everyone should buy if they want to game only, i5 7600k will bottleneck a GTX 1080, in some case it could do to a 1070 which limits performance of the GPU (the GPU could potentially output more frames but the CPU is bit weak and hold it back, especially with a 144Hz monitor)
Eleventh, that's a very expensive case.
Finally, I will make a new list for you.
3 minutes ago, deXxterlab97 said:
-snip-
Also, with $2K to spend, why not get a 1080 Ti?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
I would go with thsi instead, much better IMO for parts, you can even just get a EVAG PSU 650 if you want to spend less. https://pcpartpicker.com/list/M8Rwf8
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
33 minutes ago, Gansters12 said:
snip
https://pcpartpicker.com/list/MrTZ3F
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  ($329.49 @ OutletPC)
CPU Cooler: Noctua - NH-U14S 55.0 CFM CPU Cooler  ($64.99 @ Amazon)
Motherboard: MSI - Z270-A PRO ATX LGA1151 Motherboard  ($109.49 @ SuperBiiz)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-2400 Memory  ($101.99 @ Newegg)
Storage: Sandisk - SSD PLUS 240GB 2.5" Solid State Drive  ($83.36 @ Amazon)
Storage: Seagate - Barracuda ES 1TB 3.5" 7200RPM Internal Hard Drive  ($43.99 @ Amazon)
Video Card: MSI - GeForce GTX 1080 Ti 11GB GAMING X Video Card  ($719.99 @ Newegg)
Case: Corsair - 200R ATX Mid Tower Case  ($54.99 @ Amazon)
Power Supply: SeaSonic - S12G 550W 80+ Gold Certified ATX Power Supply  ($61.49 @ OutletPC)
Monitor: AOC - U2879VF 28.0" 3840x2160 60Hz Monitor  ($299.99 @ Amazon)
Total: $1869.77
Generated by PCPartPicker 2017-06-02 11:19 EDT-0400
This build walks all over what you have posted above, with budget left over for mouse and keyboard.
I7-7700k@5.1ghz + 1080ti @ 2050mhz + 32gbs Ram + 2TB SSD = CSGO
i7-6700k@4.9ghz + 980ti @ 1501mhz + 16gbs Ram + 1 TB SSD = Backup
i7-3770k@4.8ghz + 680 4gb + 32gbs Ram + 500gb SSD = Retired/Office work
My build
Zotac AMP card is very silent
Reviews: http://vr-zone.com/articles/zotac-geforce-gtx-1080-ti-amp-edition-review/126139.html
http://www.funkykit.com/reviews/video-cards/zotac-geforce-gtx-1080-ti-amp-edition-11gb-gddr5x-review/4/
Be Quiet Dark Rock 3 is also one of the most silent cooler you can get
6131_27_be_quiet_dark_rock_3_cpu_cooler_6131_28_be_quiet_dark_rock_3_cpu_cooler_
CPU Cooler: be quiet! - Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($64.99 @ SuperBiiz)
Motherboard: MSI - Z270 SLI PLUS ATX LGA1151 Motherboard  ($124.99 @ Amazon)
Memory: Team - T-Force / Night Hawk 16GB (2 x 8GB) DDR4-3000 Memory  ($104.99 @ Newegg)
Storage: SK hynix - SL308 500GB 2.5" Solid State Drive  ($144.89 @ OutletPC)
Case: NZXT - S340 (Black/Red) ATX Mid Tower Case  ($69.99 @ B&H)
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.86 @ Amazon)
Keyboard: Logitech - G610 Wired Gaming Keyboard  ($79.99 @ Amazon)
Mouse: Logitech - G502 Wired Optical Mouse  ($51.99 @ Amazon)
Total: $2149.18
Generated by PCPartPicker 2017-06-02 11:15 EDT-0400
CPU: Intel - Core i7-6700K 4.0GHz Quad-Core Processor  ($309.99 @ SuperBiiz)
CPU Cooler: Thermalright - Le Grand Macho RT 73.6 CFM CPU Cooler  ($79.99 @ Amazon)
Motherboard: MSI - Z270 SLI PLUS ATX LGA1151 Motherboard  ($106.98 @ Newegg)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card  ($683.99 @ SuperBiiz)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Keyboard: Corsair - Vengeance K65 Compact Mechanical Gaming Keyboard Wired Gaming Keyboard  ($59.99 @ Amazon)
Mouse: Corsair - Sabre RGB Wired Optical Mouse  ($39.99 @ Amazon)
Total: $2109.79
Generated by PCPartPicker 2017-06-02 11:27 EDT-0400
1 hour ago, PCMasterDebater said:
-snip-
Of course your build walks all over mine, because you missed the point of the build I'm going for...anyone can choose to go all out on the cpu & gpu and then compromise on virtually every area to save money. Key areas I will not change are the 1440p 144hz monitor and the case. If I'm gonna drop 2k gaming, I'm gonna make damn sure I like the case and seeing the internals I spent so much on.
Total: $2183.67
Total: $2183.67
That Bitfenix psu has the ugliest 24 pin cable known to man xD If you are going for aesthetics then maybe look at a different unit or buy a 24 pin extension cable.
For the SSD don't bother with an M.2. Just go with the regular SATA version. An M.2 slot should be saved for an NVMe SSD if you ever buy one.
I would go with the SK Hynix - https://pcpartpicker.com/product/w6DzK8/sk-hynix-sl308-500gb-25-solid-state-drive-hfs500g32tnd-n1a2a
Wow. A bit defensive?  Did you even read what I posted for you? The monitor you chose was within the build I listed for you.
Well. At least I tried to help you. Not like you ever helped me with anything.
A thank you would have been nice. You're a newbie though, most newbs think people are attacking them when they are only trying to help.
Glad to see more people recommending the 6700k; it doesn't suffer from the same thermal compound issues and is usually a steal at Micro Center too.
No need to recommend a Z270 motherboard, though.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
don't try to take everything personally
The monitor you chose was 4k, not 1440p. Wasn't taking things personally, your suggestion just seemed to lack the preferences I had highlighted at the beginning.
Yeah, a SATA SSD is all fine and stuff but the m.2 one is just $5 more so I thought what the hell?
As for PSU, I changed it to Corsair 550W RMx: https://pcpartpicker.com/product/3zNypg/corsair-power-supply-cp9020090na
And the cables don't bother me...I may just get a few from cable mod to make things look nice. I'm gonna see in from both sides anyway!
1 hour ago, deXxterlab97 said:
He is just starting a debate, look at his name
You read my name wrong. Take out the 'DE'..
Yeah. There ya go.
