Hi,
Does anyone have any idea what the "cheapest" fibre router would be that has:
VPN Client support built in (without having to flash 3rd party firmware)
802.11ac WiFi
Gigabit Ethernet Ports (not 100mbps fast ethernet ports)
I say "cheapest" because I'm still willing to spend a fair amount just would like to find the lowest cost option available. All the ones I've seen that do what I want are above $100 USD, but is that the price to expect for a router with these specs?
Thanks
https://linustechtips.com/topic/787593-router-choosing-help/
16 hours ago, JamieBritain101 said:
Hi,
802.11ac WiFi
Thanks
Pretty much yes, routers with thise features either will be quite expensive, like $300 plus, or they would give you a subscription service to a certain VPN, so then you have a monthly cost as far as I have seen anyway. The cheapest option would be to get a flashable router, that you flash with tomato for instance and then the router has more features to it for advanced users like VPN settings. This isn't a "broad" advice about them, just saying in my experience that is what I have seen, there may be models out there that do what you want tfor less, but I have not seen them.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/787593-router-choosing-help/#findComment-9926106
