 Budget & Location
SGD $2400 ( MAX $2500 )
Singapore
Got all the prices here (Pls comment if there is a better alternative)
PcThemes: https://www.dropbox.com/sh/jkxeho7zgvpsnk4/AABkZc_oaTTSMW6e5GaT0_sXa?dl=0
Aim
Main Purpose: Gaming on Max setting on League of Legends and Overwatch
Maybe some research that is needed in school
Monitors: 1 may make it 2
Peripherals: Not inclusive of keyboard and mouse but Windows OS included
Current Plan Build (Want on-board wifi or wifi adaptor)
ASUS Z270E GAMING + I7700K 853
TECHWARE ALPHA WINDOW ATX 79
WD BLUE 250GB 2.5" SSD 145
TOSHIBA 1TB 7200 RPM 63
CORSAIR VENGEANCE LPX 3000MHZ CL16 ( 8GBx2pcs ) 209
C.M HYPER 212 LED TURBO COOLER 72
SEASONIC G SERIES 650W MODULAR 169
WINDOWS 10 HOME PREM 32/64BIT 158
GIGABYTE GTX 1070 8GB G.1 GAMING 729
Total: 2477
https://linustechtips.com/topic/786939-pc-build-how-to-improve/
Ryzen would be good to look at, otherwise its fine.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/786939-pc-build-how-to-improve/#findComment-9915426
Night theme users:
 Budget & Location
Singapore
Aim
Total: 2477
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
https://linustechtips.com/topic/786939-pc-build-how-to-improve/#findComment-9915490
25 minutes ago, FTL said:
Go for Ryzen 5 1600 and B350, with the saved money, get a GTX 1080. There you go, much better performance.
Given that he is gaming, the 7700k will still be better than Ryzen 5. Even the 7600k can get you higher frames when gaming, but he should beef up his CPU cooler a bit.
Welcome to Maryland.
We have crabs.
https://linustechtips.com/topic/786939-pc-build-how-to-improve/#findComment-9915497
2 minutes ago, BOBOTanker said:
@Cyndre1033 I was going to look into an aio water cooler but I heard there's a possibility that they make leak after using it for a while and I'm not that sure which air coolers are better.
I would downgrade to a 7600k, and if you really want the ASUS board you can keep it (I love mine). Maybe something like the Cryorig h5 or h7 if they are available in Singapore. Also, ryzen might work if you put money saved into a 1080, sorta like what @FTL said.
We have crabs.
https://linustechtips.com/topic/786939-pc-build-how-to-improve/#findComment-9915537
It's not about "best gaming performance". It's about the best performance you can get for your money, and R5 1600 + 1080 will give you much more fps than the i7 7700K and 1070 (while maybe costing less).
Also, the 1600X and 7600K and both very similar in gaming performance, but since the Ryzen is cheaper (CPU + Mobo) and is better in multithreaded tasks I would get that.
@BOBOTanker
https://linustechtips.com/topic/786939-pc-build-how-to-improve/#findComment-9917215
@FTL would this be better?
ASROCK X370 KILLER SLI + R5 1600X 597
CORSAIR LPX 2666MHZ 8GB x 2pcs (16GB KIT) 212
CRYORIG H5 UNIVERSAL COOLER 85
GIGABYTE GTX 1080 8GB G.1 XTREMES 949
  2457
https://linustechtips.com/topic/786939-pc-build-how-to-improve/#findComment-9920239
  2457
No need for X370, get a B350 motherboard (you can still overclock) unless you plan on SLI (which I don't recommend).
https://linustechtips.com/topic/786939-pc-build-how-to-improve/#findComment-9922103
