It seems that whenever i open up any type of program such as the internet or games or other programs i get a very loud revving sound. This also happens at random for no reason it just revs up really loud and nothing is running or nothing has opened without my knowledge. i have tested almost every fan on my PC by either unplugging the fans and opening programs and it still happens as i have turned down my graphics card fans to 10% and up to 100% and the noise stays, if anyone has any clue what it could be or what i should check because i.am.stumped  -_-
https://linustechtips.com/topic/78673-pc-making-revving-sound/
what are your pc specs?
https://linustechtips.com/topic/78673-pc-making-revving-sound/#findComment-1080011
SO do you have a V8 in there(get it cm v8, ok im sorry). which fan is going crazy or is it all of them.
Listen if you care.
https://linustechtips.com/topic/78673-pc-making-revving-sound/#findComment-1080030
broken gearbox or bad clutch i assume.
https://linustechtips.com/topic/78673-pc-making-revving-sound/#findComment-1080034
you havent checked your psu or cpu fan have you or hdd's
stick your head in the system when its revving
Actually I just remembed im had the same issue before, it likely to be a motherboard fault, try updating the motherboard or reverting to one of the older versions.
Listen if you care.
https://linustechtips.com/topic/78673-pc-making-revving-sound/#findComment-1080036
ok enough making fun of the way i described it :P but that is literally the only way i can for that god damn noise
It's either fans or any hard drives or your computer has a combustion engine installed. Unless it's more of an electrical sound then it could be your motherboard, gpu, and possibly cpu?
https://linustechtips.com/topic/78673-pc-making-revving-sound/#findComment-1080164
Are you sure its not the hard drive?
I wouldn't want my HDDs to sound like that.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/78673-pc-making-revving-sound/#findComment-1080869
It's kind of hard to trouble shoot if you don't know where the noise is coming from.  You could put your ear up a card board tube (empty paper towel roll) and point it at different parts of the computer and try to figure out where the sound is coming from.  Basically it has to be coming from one of the moving parts: fans, power supply fans, hdd, the pump on the h80i, something in an optical drive.
First Build:| Gigabyte 990FXa-UD3 | FX 8120 4.0Ghz | Coolermaster Seidon 240M | Asus Radeon HD 7870 | Kingston HyperX 3k 120GB SSD + WD Green 2TB HDD | Corsair RM750 | 8Gb Kingston HyperX 1866Mhz CL9| Fractal Define R4 White/Windowed |
https://linustechtips.com/topic/78673-pc-making-revving-sound/#findComment-1081255
