GPU Upgrade (NOT SURE IF IN RIGHT SECTION)
PCGal
So I was thinking about upgrading my GPU. I currently have a 660, and I want to upgrade. My budget would be the price I could sell it for, plus 10-20 USD. Thanks in advanced for everyone's help.
It's the right section.
I'd guess somewhere around $50-75 is all you'd get for it, I'd suggest saving up a bit more, that way you can add an additional $75 or so to the amount you sell it for and get something decent like a 1050ti
Just now, nerdslayer1 said:
 yes, what gtx 660 do you have?
I have the gigabyte windforce 660.
Ok thanks for the idea.
From a (very) quick scan of ebay I see used 660's for like 50 bucks, that puts your budget at like 70. For that price point I recommend anything used, maybe a 770 or a 760.
R5 1600, Asus Prime B350, 16gb corsair vengeance, nzxt s340, gigabyte gtx 1060, cryorig h7, 256gb adata su800. More in Link.
https://pcpartpicker.com/list/RC4KQV
if its aftermarket, maybe around 70 and at the most $80, thats what most used 750 Tis go for and they are a bit weaker. So maybe a gtx 1050?
1
it will depend on the buyer, you can get 65 to 80$ for the card, you can get a 1050 for that or save up for a rx470( rx470 can be low as 132$ after rebate).
3 minutes ago, nerdslayer1 said:
it will depend on the buyer, you can get 65 to 80$ for the card, you can get a 1050 for that or save up for a rx470.
Ok thanks.
