My setup is:
i7 4770k
ASUS Z87-PLUS
32 GB DDR3 @ 1600MHz (Mobo has it clocked at 1333)
Gigabyte radeon HD 7970
Boots windows fine. Boots into UEFI fine. When i try to enter Advanced mode, nothing happens, pc happily idles, nothing comes on screen. Contacted ASUS, they told me to reset CMOS, did it once with the battery left in, once with it not in. Both reset the bios fine, but entering Advanced Mode does nothing.
ASUS' next step was to update the BIOS to the most current version, which I have it running, and you cant install it anyway because that requires advanced mode.
https://linustechtips.com/topic/786292-advanced-uefi-not-working-solved/
