What are the rest of your specs?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906180
Just now, NoVxture said:
rx 480, 16gb ram, xeon e3 1231 v3, 120gb ssd, and 2 1tb hdd, 650 watt supernova psu by evga.
Have you got the latest graphics drivers.
زندگی از چراغ
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906218
what's the CPU usage and GPU usage at during gaming???
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906231
1 minute ago, NoVxture said:
cpu about 70-100 percent and gpu about 90 to 100
if both of them are at max then there's a bottleneck between both of at the drops either the GPU is too slow or the CPU is too slow.
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906254
guranteed theyre not too slow i play at 1440p and get still over 100 fps maxed on rainbow six and bf1
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906260
What game? Do you notice any events that occur alongside the stutter such as drawing of distant objects?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906280
A Rx 480 (according to the numbers I'm looking at on user benchmark) should be getting an average fps of 91.5 at 1440p, and  on BF1, so yea , drops below 100fps would be normal
http://www.userbenchmark.com/PCGame/FPS-Estimates-Battlefield-1/3664/0.0.Max.1440p.0
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906281
BF 1 and Rainbow 6
2 minutes ago, App4that said:
If your CPU is at 100%, and the GPU is at 90. You have a CPU bottleneck.
it's a mix of both as both hit 100% at times so it's balanced to a point
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906287
yeah but not tp 0 randomly
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906288
in that reinstall drivers and all the other usual shit. and if none of that works reinstall windows maybe
https://linustechtips.com/topic/786181-fps-issue/#findComment-9906292
