Best headset for less than 50$
hi,i was thinking of this ones http://www.amazon.com/TRITTON-Kunai-Stereo-Headset-PlayStation-3/dp/B008KWT27W/ref=sr_1_2?ie=UTF8&qid=1385010156&sr=8-2&keywords=tritton+kunai since i was getting a ps4 and already have a vita,and so i needed a headset that worked for them too ,but now that the ps4 will work with any headset i wanna see if there is anything better than this.thanks
https://linustechtips.com/topic/78602-best-headset-for-less-than-50/
If you can stretch your budget a bit, Siberia V2: http://pcpartpicker.com/part/steelseries-headphones-51108
Plantronics Gamecon 780
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
  • 2 weeks later...
Just got a Logitech g230 from amazon for $35. Very happy with the set. They usually sell for around $50.
Hey I got a couple of questions for a G230 owner.
does the microphone work well (only records your voice)
does it mute the microphone when the boom arm  is up.
Our Lord and Saviour Chunt!!!
That's probably your best option for that budget.
http://www.amazon.com/Superlux-HD668B-Dynamic-Semi-Open-Headphones/dp/B003JOETX8/ref=sr_1_1?ie=UTF8&qid=1385925893&sr=8-1&keywords=superlux+hd668b
Those are slightly better if you can swing the extra couple of bucks.
I honestly have no idea. I don't use the mic because I don't really have any friends to talk to haha. I've heard from reviews that it isn't the best in terms of sound quality. The audio is great though.
