A couple days ago I had this power supply recommended to me for a GTX 1060.  I need an 8 pin connector for the card.  The card says it requires a 1x 8Pin PCI-E, and the power supply says it has a 1x 8pin EPS12V.  Is there a difference?  Will it still work? Thanks!
Links:
PSU: https://www.amazon.com/gp/product/B00390P1NO/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
GTX 1060: https://www.amazon.com/gp/product/B01L9VB642/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
https://linustechtips.com/topic/785111-1x-8pin-eps12v/
PCIe is for dGPU
EPS is for CPU
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/785111-1x-8pin-eps12v/#findComment-9895162
Links:
That PSU will work
Connectors: 1x 6+2pin PCI-Express is what you need
https://linustechtips.com/topic/785111-1x-8pin-eps12v/#findComment-9895178
