5 minutes ago, k_benlevi said:
Hello,
looking to read from an old SCSI drive with important information, need an amazon link to a PCI scsi card, doesn't need to be raid, just to read from the hard drive!
Here is one I found on Amazon.com:
https://www.amazon.com/Adaptec-2906-SCSI-Windows-Support/dp/B00005111H/
CPU Name    AMD Ryzen 7 1700 Eight-Core Processor
Frequency    3192.38 MHz (32 * 99.76 MHz) - Uncore: 1064.1 MHz
Motherboard Model    Asus PRIME B350-PLUS
Socket    Socket AM4 (1331)
Memory (RAM) Total Size    32768 MB
Radeon (TM) RX 470 Graphics (Polaris) [8192 MB]
SanDisk Ultra II 894.3 GiB (~960 GB)
Western Digital WDC WD5000LPCX-60VHAT0 465.8 GiB (~500 GB)
ViewSonic VX2457 (VSCB931)
Microsoft Windows 10 (10.0) Home 64-bit
https://linustechtips.com/topic/784663-scsi-need-help/#findComment-9889767
9 minutes ago, manikyath said:
$40 looks steep AF tho..
Adaptec is the must have back in the old days. And they are really expensive.
OP,
Needs to specify which type of scsi drive you have. There are a few of them. And you will need a scsi cable if you don't have one.as well as a scsi terminator.
https://linustechtips.com/topic/784663-scsi-need-help/#findComment-9889836
OP,
chances are there's a janky way to do it cheaply as well, because it really is only a "one time thing" from what i understand.
https://linustechtips.com/topic/784663-scsi-need-help/#findComment-9889861
Maybe there is, but doing it the right way is better and the janky way will probably cost just as much. Back then most of them SCSI drives were the Seagate Cheetah 15K. Modern SCSI is SAS.
https://linustechtips.com/topic/784663-scsi-need-help/#findComment-9889893
OP,
It's for Ultra-320/160 SCSI. Drive is a Seagate Cheetah 10K.7
https://linustechtips.com/topic/784663-scsi-need-help/#findComment-9906257
