You must be copying them, not moving them. Just delete them from the source device after copying them.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/784614-external-hard-drive/#findComment-9889054
i assume you mean if you drag them, they copy rather than move, its another device, if you drag and drop within a pc it moves, but from a pc to a drive it copies and vice versa, and the same would apply from the phone to the drive i would think
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/784614-external-hard-drive/#findComment-9889067
18 minutes ago, Colin_97 said:
If i transfer pictures and music to an external WD drive why do they still stay on my phone but transfer to the drive?
you're copying...not moving.
if you want to move them, do CTRL + X then CTRL + V on the WD Drive
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/784614-external-hard-drive/#findComment-9889129
6 minutes ago, Colin_97 said:
I could also just delete the pics from my phone now that theyre transferred onto the drive right?
If you're certain which ones you backed up.
Main System: Phobos
https://linustechtips.com/topic/784614-external-hard-drive/#findComment-9889171
yes, if you're sure you've backed up ALL of them
Old Rig
https://linustechtips.com/topic/784614-external-hard-drive/#findComment-9889257
