This is gonna be my first build and I was wondering if I could get any suggestions or help with it. Any and all help is very appreciated!
CPU: i5-7600k
CPU COOLER: Corsair H115I SIP
MOBO: ASUS Maximus IX Hero
RAM: G.Skill Ripjaws V 16gb (8gb x 2)
STORAGE: Seagate Barricuda 2TB HDD
Samsung 850 EVO 250gb
VIDEO CARD: EVGA 108ti FE
CASE: Coolermaster MasterCase pro 5
PSU: Corsair CSM 750w 80+ gold semi-modular
**EDIT**
MOBO: ASUS z270h
VIDEO CARD: EVGA 108ti SC
PSU: EVGA Supernova G2 750W 80+ gold
All of your help has been highly appreciated!
https://linustechtips.com/topic/783893-first-build/
Budget? What is it being used for? Use PCPartPicker.com for your build lists ples.
https://linustechtips.com/topic/783893-first-build/#findComment-9880330
What do you intend to do with this build?
Get a cheaper motherboard and cooler and grab a i7-7700K instead.
The GTX 1080Ti FE is a blower-style card so it's going to run hotter and louder than your typical aftermarket card. Grab a GTX 1080Ti that uses a third-party open air cooler instead.
Lastly, the power supply could be better. Grab a EVGA SuperNOVA 550 G3 instead.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/783893-first-build/#findComment-9880338
Don't get i5, get Ryzen 5/7 or i7
Why AIO, a good air cooler can perform almost the same with AIO at much lower price
Overkill mobo
Don't get FE card, runs hot and loud
Corsair CS PSU is overpriced, you can get a much better PSU for the same price
Edited by ZM Fong
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/783893-first-build/#findComment-9880340
2 minutes ago, nerdslayer1 said:
ryzen 1600, an i5 will bottleneck anything over a rx480/1060.
I've seen i5s with 1070s before no bottle neck
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/783893-first-build/#findComment-9880343
Any motherboards you recommend?
https://linustechtips.com/topic/783893-first-build/#findComment-9880345
Overkill mobo
Any mono, psu, and coolers you suggest?
https://linustechtips.com/topic/783893-first-build/#findComment-9880358
Practically any Z270 motherboard is fine since the VRMs on them should handle a i7-7700K well.
If you want to retain the "gamer" look of the Maximus, have a look at the STRIX Z270H.
https://linustechtips.com/topic/783893-first-build/#findComment-9880360
Mobo: Asrock AB350M Pro 4, MSI B350 PC Mate, Gigabyte AB350M Gaming 3 and many more
PSU: Corsair CX-M grey, Seasonic M12II-EVO and EVGA B3 are among the cheapest options
For CPU cooler, here:
Desktop specs:
https://linustechtips.com/topic/783893-first-build/#findComment-9880418
So do you recommend the cooler master hyper 212 EVO or the noctua nh d115
https://linustechtips.com/topic/783893-first-build/#findComment-9880461
Hyper 212 EVO is very mediocre, would not recommend it
NH-D15 is an excellent cooler.
Desktop specs:
https://linustechtips.com/topic/783893-first-build/#findComment-9880486
2 minutes ago, EliteLastOne said:
You mentioned earlier I should get a better psu any suggestions?
Or get any tier 1-3 PSU from here:
Desktop specs:
https://linustechtips.com/topic/783893-first-build/#findComment-9880596
