Case fan setup
Solved by LogicalDrm,
1 minute ago, 4yellowflash said:My case sir is a techware f3, I will try your suggestion sir, thanks sir
Yeah, you can do 2 front in with that. Exhaust either top or rear. Rear might be bit better.
IAmAndre ·
8
1
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
1
kasdashd ·
4
play_circle_filled
Latest From ShortCircuit:
