Posted May 22, 2017 Hello again! I'm currently in the project of building my friend a gaming PC for his game room, I wanted to go with an AMD Ryzen 5 CPU and my friend wanted to know if we could try water cooling it. Any suggestions? (I can go a bit over the budget) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 22, 2017 Aio or custom loop? I would rather agree on what we share, than fight on what we don't. - Myself FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 22, 2017 After the loop for GPU and CPU, you'd have maybe 650 for the PC, not worth it Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 22, 2017 22 minutes ago, Ryhann said: Hello again! I'm currently in the project of building my friend a gaming PC for his game room, I wanted to go with an AMD Ryzen 5 CPU and my friend wanted to know if we could try water cooling it. Any suggestions? (I can go a bit over the budget) If he wants just an aio sure, but a full loop is not worth it. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2017 IMHO: Custom water cooling is not something you should be looking at if you're on a fixed budget. --- Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2017 even with a EK-KIT S240 ($200) and adding a GPU block and fittings (~$100) you would only have $700 for the PC. EK kits would be a nice affordable starting point if you wanted a cutsom loop. You could do 2 AIO (1 CPU + 1 GPU for around ~$200 if you want to annoy me, then join my teamspeak server ts.benja.cc Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
