Urgent, need help! Mobo, cpu issue?
Solved by XR6,
2 minutes ago, MarcusLauk said:Yes, it seems like my original psu shorts out and instantly shuts when the 24 pin is connected, i can start every other circuit without it shutting off. I can audibly hear the fuse shut on and off. I think the 24 pin cable is the culprit since it shorts the psu without being connected to a motherboard.
I agree. Try replacing the 24 pin cable and see if it actually is the issue though (it has to be, but you never know).
Your PSU isn't the problem as you've verified it's working fine and from what you've said it seems to work without a fault.
